Help! My front yard is kicking my butt! Bushhogging uphill
   / Help! My front yard is kicking my butt! Bushhogging uphill #61
OK. What psi are you running your in your rear tires?
   / Help! My front yard is kicking my butt! Bushhogging uphill #63
You need a Steyr;)
   / Help! My front yard is kicking my butt! Bushhogging uphill #64
   / Help! My front yard is kicking my butt! Bushhogging uphill #65
What do you mean by "low"? There is no low on my tractor.
Are you saying that your tractor doesn't have a range selector. I have never seen a "TRACTOR" with HST without at least 2 ranges, most have L, M & H range selectors. Lawnmowers may only have one range and only controlled by a single pedal for forward and reverse but not tractors. And of course if it is gear drive it is going to have at least 4 gears minimum. Mine has 20 forward and 20 reverse.
   / Help! My front yard is kicking my butt! Bushhogging uphill #66
The GST I have doesn't have "low" or "high" gears, just 1-12 or so for forward and then 1-8 or so backwards.
I go up in "4" gear and come down in "5" gear. I keep the PTO rpms right 540 +/-, which do require changing the throttle input to keep the rpms the same.
Sure seems like it.
   / Help! My front yard is kicking my butt! Bushhogging uphill #67
I think his tractor is a L4330 GST here is a link to it's specs..
Kubota L4330GST 4WD Tractor
   / Help! My front yard is kicking my butt! Bushhogging uphill #68
Kubota*L4330GST*4WD Tractor
If it is a glide shift then it for sure has a low gear. 1st would be lowest and might not be the "low gear" than is needed but however you slice it everything mechanical that moves via a transmission has a lowest gear and a highest gear. Just because it doesn't say L or LOW on it doesn't mean that it doesn't have one.
   / Help! My front yard is kicking my butt! Bushhogging uphill #69
I think I said that before, use a lower gear it may be he needs to use the lowest gear to go uphill safely. Not ideal of course but safest and cheapest for sure.
   / Help! My front yard is kicking my butt! Bushhogging uphill #70
Its not speed or power. Its a traction issue. ... And R4s suck at it - particularly on turf. For the OP to optimize what he has he needs to make the tractor heavier, particularly the rear since it has a FEL. And lower tire pressure to increase active tread area. Those R4 lugs could also be grooved as a last resort before going to R1s.
-- The key problem is probably the hi grass/vegetation on the subject mow. If OP can get thru it, regular mows after should be within normal capabilities of R4.
Mini John Deere Truck (A55853)
Mini John Deere...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: 132,994 Plate: Body Type... (A56859)
Year: 2014 Make...
2019 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2019 Peterbilt 389...
2022 CATERPILLAR 301.5 EXCAVATOR (A52709)
2022 CATERPILLAR...
2017 Ford F-550 4x4 Cab and Chassis Truck (A56858)
2017 Ford F-550...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 27ft x 24ft...
