Help me pick a mig welder
   / Help me pick a mig welder
Cord,,,I want you to take this the right way,,,its the welder,,not the rod,,if somebody else can do it....
A 7010 rod is about same as 6010 maybe a few more snaps/sparkes,,,,,it is an all postion rod,,I have welded over head with it,[alot],like 6010 better,like 6010 plus a lot better[6010+],,but ,,,,,what kinda rods have you run??Why have you been using 7010 rods,,they are called hipy rods,,[high yield point],,hippy rods ///high yield point rods,,,get it???,well,,they are pipeline rods,,why are you using 7010 rods???
You need to get you some 6010 + rods,lincoln,,good rods,,
You turn your machine up,not down to make arc more stable[if you are having trouble sticking or maintaining arc],,,wish I could show you,but I can't.
I'm using quality rods from a welding store. Can't tell you the brand. Tried the local farm store crap and returned them immediately. I like the 7010 rods because I tend to rush (always fearing a burn through) and they're more forgiving than the 6010 (which I also have). The 7010's are a semi drag which I love. Wish I could find some 7040's. Used some 1/4"x16" 7040 rods in high school and they were incredible. The problem is that I'm welding at the very bottom of the welders scale. If I recall correctly, around 130 amps. Yes, it's a hot machine. The issue is that turned down all the way, I'm still throwing too much heat into the rod so my puddle tries to drop out. Turning the welder up does help, but I run the risk of burn through and have turned the rods red hot. I've compensated by switching from 1/8" to 5/32" rods, but the machine really wants a 1/4" rod.
This is not my welder, but it's a very similar model. Mine doesn't have the reverse polarity switch. Welder I scored mine 10 years ago for $35.
   / Help me pick a mig welder #22
Well,sounds like that machine just can't be turned down below a certain point? for some reason,, You should be able to burn 1/16 inch rods as well as 3/16 on a 200 amp machine,just by turning a knob up or down,,don't know what it is?
Maybe you just got a problem machine,,you need to try out another machine,,bet its just that machine you got,,you should be able to weld 1/8 inch thick stuff with 3/32 rods and 1 inch stuff with 5/32,[need a few passes with the inch stuff]...
Instead of a mig,,you should buy you a new stick machine,miller makes all kinds,,dc output,,transformer like you got or gas/desil powered,,,sounds like you burn big rods,so 200 amp or more one..but if you had the right welder,you could stop burning them big rods unless you really needed them.
Yea, I've used a tombstone welder in the past and had really good welds with it. Almost didn't want to give it back. As for turning it down... yea, I'm not surprised it can't go any lower. After all, it's rated for 500 amps at 50% duty cycle! I can't imagine what kind of rods you'd need to weld with that kind of power.
   / Help me pick a mig welder #24
Both Lincoln and Miller are good welders. I've used migs made by both. I own a Miller.
Buy from a dealer. Not a big box.
Lincoln is supposed to be an amazing company. Based in Ohio. They a very American product. Lincoln has a life time employment policy. If you make it through probation and follow the rules you will always get a paycheck. They also have a very generous profit sharing with there employees.
   / Help me pick a mig welder #25
500 amps at 50 percent,,,well there you problem..and you knowed that,,but now we all do...no wonder your burning them giant rods..
This is my thought,,you have experience stick welding,right,,get you a ac/dc around 200-250 amp transformer machine[stick machine],lincoln or miller,,you should be able to use 1/16th to 3/16[or so],,that should do you....than if you want a mig,get you one.
Mig to me is handy but unless your wanting to weld sheet metal or aluminum,,they ain't much use to me.:)
   / Help me pick a mig welder #26
Cord, you got the welder that I wanted but could not afford--I got a Esab C-170 and have had it for about 2 years now. I really like it. It is the first wire feed that I have had and I find myself doing things with it that I would never have even contemplated with stick. I have welded quite a bit of 2 mm thick material and have found it to be very stable and consistent. I use CO2 for a shield gas.
Mike
Mike
Yea, people are not familiar with the Linde/L-tec/ESAB products so they default to the Lincoln/Miller lines. Those that have tried the ESAB and own Miller have repeatedly said that ESAB is better. That's not a bash on Miller, it's just that ESAB is that good. But for the price it should be!
Yea, I'll be shopping for gas on Monday. I'd rather not rent the cylinders, so we'll have to see if they're even willing to sell them. Years ago when I got into my torch set, nobody wanted to sell cylinders to me. The pain is having to recertify the cylinders every few years.
   / Help me pick a mig welder #28
If you wish, try flux core wire too, it is very similar to stick. Lots of wire to choose from, gas and gasless, find your favorite. :thumbsup:
   / Help me pick a mig welder #29
It shouldn't be hard to find a cylinder, the problem may be the size they're willing to sell. All I could get was the small "hobby" cylinder, the larger ones are lease only, at least they are here. Having said that, unless you're doing a lot of welding the small bottle is fine.
I've got a Miller 180, had a Miller 135 before that. I actually think I liked the 135 better, the only advantage the 180 has is more power. You'll be pretty happy with the Esab, I think. Any major name is going to be a decent welder, the only ones I'd be leery of are the Harbor Freight/Princess Auto cheapies. The box store models aren't much better, generally speaking.
Sean
   / Help me pick a mig welder #30
Lincoln Powermig 255 & 225 Tig here.
My next will be a Lincoln 140c, I think you can get this in your price range, and IMHO is a kickass welder for the price. :thumbsup: I`ll get it when I start doing more sheet metal work, and don't want to keep switching wire/consumables on the bigger machine. This one also sits nicely on my TIG :laughing:
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A58017)
2020 INTERNATIONAL...
1449 (A57192)
1449 (A57192)
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2020 John Deere 5065E 4 x 4 Tractor, S/N 1P45065EPLK406145, John Deere Diesel Engine, Cab, 3 Point (A59076)
2020 John Deere...
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
SCALES & PEA (A58374)
