Help...Cub Cadet 3000 series won't run more than 3 minutes
   / Help...Cub Cadet 3000 series won't run more than 3 minutes #1
GTSRider
Cub Cadet 3000
Put in new factory carb, new factory fuel pump, and tractor won't run more than 3 -4 minutes.
Bought it used , and was supposedly gone over....but I am thinking fuel line was not routed correctly
and has kink in it....will remove seat and install new fuel line..... any other suggestions, or thoughts ?
Tractor is 2003 3206 model.
Thanks,
Pete
Hudson Valley , NY
   / Help...Cub Cadet 3000 series won't run more than 3 minutes #2
Does that model have a fuel filter between the tank and the pump? If so I would replace the filter, if not I would pull the fuel line off the tank and let it run out for a little bit because there's probably some kind of junk in the tank that is blocking the fuel outlet after it runs for a few minutes.
Aaron Z
   / Help...Cub Cadet 3000 series won't run more than 3 minutes #3
That sounds like just about the right amount of time for an electronic ignition component to be heating up and failing. Like the coil/ignition module.
   / Help...Cub Cadet 3000 series won't run more than 3 minutes #4
Or it runs just long enough to form a vacuum in the fuel tank.
Check the fuel tank cap, make sure that the vent is not plugged.
Richard
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
Excavator Bucket (A50860)
Excavator Bucket...
tiller (A50860)
tiller (A50860)
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
2013 GMC Sierra 3500HD 4WD Cab and Chassis Pickup (A50860)
2013 GMC Sierra...
1999 24DTA pintle hitch trailer (A51039)
1999 24DTA pintle...
