Help B7309 Install Instructions
   / Help B7309 Install Instructions #1
mswlogo
NH, USA
Kubota B2320 DT (Gear)
I believe MB Tractor botched my B7309 install. Duel setup.
Does any one have the install instructions that they could possible scan and PM me?
I took all 4 couplers off and nothing comes out of any of them except a little spit when I move the controls.
Also is there any standard on what should be Male and Female.
I always thought you'd have one Male, One female for each Valve.
I've seen some posts that folks put all female on the Valves.
MB Tractor Put Males on One Valve and Females on the Valve.
I figured it out. They did F it up.
They mixed the lines up.
I more or less used trial and error with slight educated guesses. It couldn't have been much worse than it was.
Owners manual is terrible about explaining where ports are for my Tractor. The only one clearly explained was the Tank. Which helped reduce the options.
I didn't feel like taking wheel and fender off to just find possible labels.
My first swap got the new valves working but I broke the 3 PT Hitch (which was working).
One more swap and they both worked.
Not so keen about these Valves. It looks so non factory it's not funny. I'll probably move it.
The spacing between the ports is ridiculously tight. Spacing between controls is tight too.
And the couplers supplied were near useless sizes. I believe they are metric sizes.
I wish now I had done it all myself and I think I would have ended up with nicer valves for less money.
   / Help B7309 Install Instructions #3
In answer to question about quick couplers if it's a tool cht. install male on pressure port if its work ports install one male and one female on valve then opposite on hoses to keep from hooking up wrong. sounds like installer wasn't paying attention or needed instruction
(APPROX 15) 6" X 2" X 68" TUBING (A57192)
(APPROX 15) 6" X...
2010 FORD F550 XL SUPER DUTY SERVICE TRUCK (A57192)
2010 FORD F550 XL...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
LaneShark LS3 (A56469)
