HELP! 3320 Range lever knob removal question.
   / HELP! 3320 Range lever knob removal question. #1
OrangeJbird
NW WI
3320 w/300cx FEL
I need to take out the black plastic operator station cover so I can repair my loader lever linkage.
How does the orange cover on the range selector lever come off? Is it snapped on? I started to pry a little with a screwdriver and don't want to break it.
Also, how to remove the rate of drop knob below seat front for 3-point. Unscrew it?
Thanks for looking.
   / HELP! 3320 Range lever knob removal question. #2
Hello, I had an older 4300 hst and I believe the knobs are the same for removal. The range lever orange cap snaps off and inside you will find a screw to completely remove knob. I believe the rockshaft rate of drop knob will pull straight off. I have attached photos of a 2012 3320 parts diagrams. If your tractor is another year model you can go to JDParts on line. I hope this helps.
   / HELP! 3320 Range lever knob removal question. #3
Yea, pop the top off the range lever and you'll find a 10mm bolt that's holding it on. The 3 point has an allen head screw at the base of the shaft. Loosen and pull off.
Any suggestions to "pop the top off the range lever?"
I tried prying it with various tools to no avail.
Can't see an allen screw on the other knob. Will look closer.
Thanks
   / HELP! 3320 Range lever knob removal question. #5
I had to take a small scraper to get under the top of the range lever to pop it off. It was on there pretty good before it finally popped off. My 3 point rate of drop lever has a small allen head bolt recessed toward the back. My 3320 is an 2006, they may have changed to just a pull off style on newer models.
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
1269 (A50490)
1269 (A50490)
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
16ft Tilt Trailer (A48082)
16ft Tilt Trailer...
2020 JLG 1732 4x4 Rough Terrain Telehandler (A49461)
2020 JLG 1732 4x4...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
