HATZ engine
   / HATZ engine #1
Bigonedodge
MF690
Can someone confirm which way a Hatz E673 RHK diesel engine should crank when looking at the starting handle ie. Opposite the flywheel
Thank you
   / HATZ engine #2
Not sure what the "RHK" means or if it's related to the direction of rotation but there is a video on Youtube of the same engine but a "LHK" and the handle spins clockwise.
When in doubt, put your hand over the exhaust and give it a spin by hand. When spinning in the correct direction, you should feel air blowing out of the exhaust. If it's sucking air from the exhaust, it's the wrong direction.
2012 MACK CHU613 (A58214)
2012 MACK CHU613...
SCALES & PEA (A58374)
2317 (A58376)
2317 (A58376)
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2013 Yamaha YDREX4 Golf Cart (A56859)
2013 Yamaha YDREX4...
LOT: (2) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (2) Kimball...
