hard cranking jinma 284
   / hard cranking jinma 284 #1
rut2nut
I have a 05 jinma 284 that i just put back together for the 2nd time, different story.The tractor will crank right for about three or four turns then start to turning like the battery is dead.wait four or five min, and it does same thing all over again. new battery 750 cca,all other electrical components work good.any ideas? thanks r2n
   / hard cranking jinma 284 #2
rut,
You might want to ask this question in the Chinese tractor section to see what other Jinma owners come up with.
If you haven't done so already, since you have a new battery, is take the ground from the battery off the frame. Then use an angle grinder to remove any paint or rust from the frame down to bare metal. I used a star washer to reconnect so it "bit" into the metal for a super good connection. Check voltage of the "new" battery too. Sometimes the connection will be good enough to get the starter to crank, but if it's not perfect, it will start to oxidize and you'll lose current as there is more resistance from the poor connection.
You'd be surprised how many electrical problems stem from a poor ground, even if it looks good. Try that first and go from there.
You can use your decompression lever to let it turn over easier, but it sounds to me like a bad connection.
   / hard cranking jinma 284 #3
I'll double up on the ground. I will put a ground line directly to the starter frame for just that reason.
Other than ground, check all wires for tightness and corrosion.
   / hard cranking jinma 284 #4
Or your starter may be ready to take a dump. When it slows down is the starter hot. If it is it's time for a new one. Why did you have the tractor apart. Could you be building hyd. pressure and putting too much load on the starter.
Bill
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2016 BE Pressure PE-4013HWPAG Pressure Washer 4000 PSI Gas Cold Water (A48083)
2016 BE Pressure...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2013 Chevy Silverado 2500 HD (A51039)
2013 Chevy...
