Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #15,171
I have the Astro Pneumatic Tools brand snap ring pliers and they look identical to yours.
   / Harbor Freight Tools that don't suck #15,172
I really like my astro pneumatic 20gal parts washer it's one of the few in that price point the pump can handle petroleum based parts washing fluid, unlike my previous hf version.
   / Harbor Freight Tools that don't suck #15,173
and you can run it with only one hand? Wow impressive! 😉
I have for brief periods when my hands cramp up. I'm basically just keeping it from falling over, it does the bulk of the work by itself, depending on what I'm hammering through. I'm not busting through 12" of concrete reinforced by rebar, though. Just 4-6" with wire in it.
   / Harbor Freight Tools that don't suck #15,174
But did you answer the phone like he did?
   / Harbor Freight Tools that don't suck #15,175
Everything on my Massey GC1723 is metric, so I bought two Pittsburgh Pro metric socket sets from Harbor Freight. I don't see anything subpar about these tools. $27.99 for the 1/2" drive set and $23.99 for the 3/8" drive set. How could you go wrong with those prices?
   / Harbor Freight Tools that don't suck #15,176
Everything on my Massey GC1723 is metric, so I bought two Pittsburgh Pro metric socket sets from Harbor Freight. I don't see anything subpar about these tools. $27.99 for the 1/2" drive set and $23.99 for the 3/8" drive set. How could you go wrong with those prices? View attachment 769701View attachment 769702
I might be buying a set of these for my SIL, for Christmas. Trouble with buying him tools is that he loses them as fast as I can buy them. Grandson looks to have the same trait...
Does HF have any tools with a built in Location Finder?
   / Harbor Freight Tools that don't suck #15,177
Gstrom, have Santa give a strong magnet and let them all share
when I can't find a socket, I usually remember to look on the end of the ratchet or extension...
Wish they would stamp the sizes into the case, something to visually locate the size easier.
   / Harbor Freight Tools that don't suck #15,178
I highly recommend the Astro Pneumatic Thor 1/2" drive air impact wrench. Torque Test Chanel on YT has had it in the top spot for air powered impacts for a long while. it's not all that expensive but does require high flow couplers and larger diameter air line. After purchasing the Thor, I gave away my IR Thundergun. The Thor makes around 1500 foot pounds of break away torque and 1000 foot pounds of tightening torque which puts it in the realm of a 3/4 drive impact without the weight of a 3/4 drive which I also have but in the IR flavor. Astro makes some very nice and not all that expensive air tools. The Thor will bust Bud style wheel nuts no issue. Haven't used my torque multiplier in some time now. One aspect of the Thor I like is, it will either loosen A325 Dome head plow bolts on wear steel bottoms or twist them off. No penetrant needed.
The only issue is, it will split impact sockets of they are not really stout. I've split Snap on, SK and Proto already. The only ones that hold up are the Harbor Freight black oxide sockets, believe it or not. Yet to split one of them.
   / Harbor Freight Tools that don't suck #15,179
Nice thing about HF sockets is the lifetime replacement policy. I've split a few by using them on an impact (regular ones, not the black oxide impacts) and returned them to the store and they replaced them, no questions asked.
I would not buy their pinned universals. They won't hold up. I'd go with the broached universals that Astro sells.
   / Harbor Freight Tools that don't suck #15,180
I have a bunch of hf black oxide impact ones I used them extensively when I used to build semi custom truss framed floating docks. Drop one in the lake or river not a big deal,at that price, plus as mentioned they'd never break and being 6 point rarely stripped out nuts, bolts, or lags.
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
FIMCO 60 GALLON SKID MOUNT SPRAYER (A52708)
FIMCO 60 GALLON...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
2015 Mitsubishi Outlander Sport SUV (A56859)
2015 Mitsubishi...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
