Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #8,961
Those and the lights. I'm always looking for a darn flashlight it seems.
Several years ago I took 30 of those little cylindrical flashlights to give away,.... on a trip to Cuba.
   / Harbor Freight Tools that don't suck #8,962
The reels are nice. Before the discount versions came out at places like HF the price was just too high so I use spare steel wheels. Often you can go to a junk yard and find one that's a little damaged so it can't be used on a car. They work great for everything from air hoses to electrical cables. Back when I had my tombstone welder that was too heavy to move around I had over 100' of cable for it and chrome wheel mounted to the wall next to it to wrap the cables around when not in use.
I bought a HF one that was on clearance because it was missing the handle to turn it, and once I got tired of just turning it by grabbing the rim, [and SWMBO complained] I used the side handle from a [dead] HF angle grinder to replace the missing OEM one....
   / Harbor Freight Tools that don't suck #8,963
The air hose reel I bought is the spring loaded retractable type. No hand reeling required.
   / Harbor Freight Tools that don't suck #8,964
I recently counted and I have 17 of those free magnetic strips. I took a short piece of 1x2 and screwed the magnetic strip to it, then drilled a bunch of 1/2" holes through it. It snaps right to the side of my HF compressor and holds chucks and blow guns.View attachment 550334
Gotta do something like that as I always am looking for the blow guns, inflators etc etc.
Good post and good reminder.
One thing that helps is that I add a 'whip' (like 12 -24" on each inflator)
   / Harbor Freight Tools that don't suck #8,965
......I suspect it would have been more obvious this was re-taped if it were next to a new one. I think I'll write DAMAGED HOSE on the box before I return it....
Just make sure that you do it after you show it to them, or they're going to say that you should have known it was damaged....
I have had too much trouble with the retraction springs on any such [hose, cord, etc] failing to go that route again.
   / Harbor Freight Tools that don't suck #8,966
On the small freebee flashlights, I must a dozen of them and for whatever reason, I think all of them still work. And while other pricier flashlights I have died, the HF cheapies keep on going and in some cases are my preferred flashlight. They fit in my coat pocket, are easy on batteries and when I drop one they just keep working. Beats me.
   / Harbor Freight Tools that don't suck #8,967
Well FUDGE! The hose reel I bought had been sold and returned. It was packed back nice enough but they had rounded off the wrench hex on the hose and returned it with a coupler that was leaking. I called myself leak testing it before I mounted it to the ceiling but somehow over looked that. I thought it was strange that it came with a coupler installed. Now to man handle this thing back down and return it. Pisses me off they said they had a dozen in stock when I called today but this was the only one on the shelf when I was at the store. I suspect it would have been more obvious this was re-taped if it were next to a new one. I think I'll write DAMAGED HOSE on the box before I return it.
On second thought I may just put a BH in a spot on the box where it's not obvious then explain to them it was damaged and should not be resold. Then if it's convenient I may go back in later to see if they put it back on the shelf. Sneaky Huh?
   / Harbor Freight Tools that don't suck #8,968
Hehehehe! :laughing::cool:
   / Harbor Freight Tools that don't suck #8,969
I bought one of those reels at a black Friday sale at least 10-15 years ago. The hose had to be replaced a couple of years ago but no other problems with it.
   / Harbor Freight Tools that don't suck #8,970
I actually took the supplied stanky [and BTW very stiff and hard to use in colder temps] HF rubber hose off of mine and replaced it with a softer, more cold-friendly one I got on clearance from TSC- SWMBO loves to use it now.
WINCH CABLE DRUM (A58216)
WINCH CABLE DRUM...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2830 (A58376)
2830 (A58376)
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
Kubota M5-091 (A57148)
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
