Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #12,811
I would be careful about using an acid (vinegar) in the HF ultrasonic cleaner I have. The tub is aluminum. It works well, but I find it doesn't clean brass as well as I would like.
   / Harbor Freight Tools that don't suck #12,812
I'll keep my tumbler with corncob media for brass and small metal parts..
   / Harbor Freight Tools that don't suck #12,813
But it's a "super-dooper" vibrating tub.
Actually it is more than that.
Sound waves create bubbles that contains a great amount of energy. That energy is contained in the tiny bubble so when it bursts it creates a scrubbing action.
Add a cleaning solution and you have a micro-power washer of sorts.
I am sure none of my description is technically accurate but that is my interpretation of what happens.
Yeah the frequency is relatively high such that you really can't tell it is vibrating.
Not sure if mine is a polished aluminum or stainless steel liner. It is very thin wall. I do clean and dry it out thoroughly each time I use it.
   / Harbor Freight Tools that don't suck #12,814
That may sound sarcastic, but it's actually the truth. Basically it's a smaller controlled form of cavitation that eats up poorly designed or maintained cooling & hydraulic systems. It disperses soft material (dirt & grime) while leaving metal & hard materials like metal alone. Uncontrolled cavitation can eat holes in the metal.
   / Harbor Freight Tools that don't suck #12,815
I have both the 2 liter ? and pint models. The larger one is used for typical parts cleaning but all I use in it is Simple Green or similar cleaners. The smaller one I use to clean my dentures nightly. I fill it with hot water and add a Polident tablet. It works very well. I also use it to clean the cutting head of my Norelco razor by covering the head with hot water and putting just a squirt of liquid hand soap in it.
I clean it after each use and store it up side down so no water runs down to the electric parts.
   / Harbor Freight Tools that don't suck #12,816
One thing about this site, you ask a question you get a good answer (most times), I had no idea how an ultrasonic cleaner worked. Now, I do.
   / Harbor Freight Tools that don't suck #12,817
The amount of experience and knowledge in this group is sometimes staggering.
   / Harbor Freight Tools that don't suck #12,818
95% good advice, 5% very BAD advice. One has to know the difference.......:D
There are some very frequent posters on here (will remain nameless) that are entirely FOS to the very top and keep right on giving bad information like it's a game with them. I actually have them on ignore, a nice feature of this forum.
   / Harbor Freight Tools that don't suck #12,819
I was a little disappointed that HF only has a 20% coupon for president's day weekend. On top of that they act like it's a special coupon since it's only good for 4 days. It has the same restrictions on what you can't buy and it's only good for one item. I'm thinking of getting a 2 ton engine lift. The current coupon for the lift is slightly better than 20% off but less than 25% so I've been holding off until this weekend. It's only about $10 so no big deal but I'm wondering if HF is going to phase out the 25% off?
   / Harbor Freight Tools that don't suck #12,820
I’m thankful for the 95%, the rest sometimes has me shaking my head hoping those asking can tell the difference and avoid the potential perils. Sad that some people get their kicks knowingly put out BS. Wife has a brother like that, thankfully he’s gotten a bit better with age. He thinks it’s humorous - NOT.
NEW Long Forks (A59000)
NEW Long Forks...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
Deere 35G (A53317)
Deere 35G (A53317)
2010 International 7600 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2010 International...
1R CULTIVATOR, 3PT (A52708)
1R CULTIVATOR, 3PT...
KING KUTTER SCOOP PAN (A52708)
KING KUTTER SCOOP...
