Handling Filled Tires
   / Handling Filled Tires
Thanks to everybody for the good advice. Especially the point about taking off the wheel disks. I never would have thought of that. That's a trick you either have to learn the hard way, or learn from an experienced hand. I'm still trying to come to grips with the reality of moving something that heavy, even though it's round. I also hadn't thought of the necessity of using a pry bar to move the tire in and out to line it up.
This might seem like a dumb question, but since you have to swap sides to keep the tread in the right direction, you have set the first tire aside somewhere. I wonder if I could lean it slightly against the wall?
I heard an interesting opinion, that if I was just moving the wheels out for use with chains, you could just pull each rim off and spin it around. The tread direction would now be backward, but supposedly with chains on it wouldn't matter. I'm hoping that I will leave the wheels spaced out once I change them, chains or not, so I wouldn't want to do that.
Still trying to get the courage up to tackle this project. I always prefer to do things myself if at all possible, but sometimes that gets me in trouble. Seems like once the bolts are removed I will have passed the point of no return...
   / Handling Filled Tires #12
After you had one wheel/tire off you could remove the center disc and reverse it, bolt it back in the wheel and then put the tire/wheel back on. (If this what you are trying to do) that way the tractor will always have one wheel/tire on, vs pulliing both and swapping side to side.
   / Handling Filled Tires #13
I have moved 18.4x34 with full ballast and as long as you keep them balanced upright they are easy for one strong man to handle. X3 on removing the tire from the wheel lug nuts and not the rim bolts. It is not hard to get the tire aligned with the lug nuts. It should have two stud sticking out so all you have to do is align those and slide it up. You need to have a good pry bar to slide the tire with. You will need to be able to slide it side ways once you get it lined up with the holes. This is where a buddy is handy to have, you need one pair of eyes watching the lug alignment while the other positions the tire. One can do it but it is hit and miss on hitting the bolt holes and might get a little frustrating. The hole aligner doesnt need to be big and brawny just able to see and tell you what direction to move the tire, a wife would do for that. Proper safety instructions would need to be given in that "If I yell, I'm loosing it, get out of the way", the helper immediately gets far away and allows the tire to fall. DONT try to stop it if it gets out of balance , just move and let it fall then worry about getting it back up. A water filled tire can break you leg or worse if it falls on you.
Glad to hear an 18.4-34 loaded is doable. I need to pull the left off my JD 6415 to install a fuel tank guard. My plan is to find out what size the axle hub bolts are and get two more as long as possible and cut off the heads to make guide studs. I am thinking of using a pallet jack and pulling the wheel/tire straight out far enought to install the fuel tank guard.
I have successfully R&R a 16.9-28 that was loaded and had a cast iron center.
   / Handling Filled Tires #14
That size tire is very manageable without special equipment even when loaded. Keep them upright. You will find it much easier to remove the center disc and wheel from the axle, re-position the disc on the rim in the proper setting, then replace the disc/wheel assembly on the axle. Re-torque ALL hardware after a few hours use, and continue to re-torque at intervals until the hardware is fully tightened.
I'm with you on this Rick. Like on a MF135 there are many combinations to bolt the rim to the disk to get the spacing you want. Doing it with the entire wheel off the tractor would be the easiest. I can't imagine trying to line those holes up rim to disk with loaded tires. I'd also suggest positioning the tractor backed up close to a solid wall so when you removed one you wouldn't have far to go to lean it against.. I would also break all the nuts loose ( rim to disc) (wheel to hub) before jacking it up and removing the entire wheel. Leave them snugged but you can exert more forced leverage with the wheel still mounted. Just like you would do an auto wheel.
   / Handling Filled Tires #15
If you had a 4 wheel dolly, you could jack the tractor high enough, remove the tires onto the dolly and roll them into place. Be careful as was said, if it starts to fall just get out of the way !!!!!!!
That's about the most dangerous way I can think of to (try to) move tractor wheels. I'll bet that is a keyboard dream that has never been attempted by the person that posted. The darn things are round; they will roll just fine on their own.
When I was doing road service full time I routinely removed loaded 16.9x30's on New Holland tractors by myself to access the transmission control valve. Usually doing this job by myself is easier than coordinating movements with a helper. Not to say having someone around if things go south is a bad idea.
   / Handling Filled Tires #16
yep.. upright.
I'll roll up to 13.6-28 loaded .. if they are larger I 'loader' them into place then move around.
14.9-28 and 16.9-24 are the heaviest i've moved without laoder help.. and both of those were probably too heavy to be safe.. thus my new lower range.. :)
be safe.. and if it starts to go.. let it and jump out of the way.. you can always leverage them up later while you aren't hurt.
   / Handling Filled Tires #17
Another point to watch is how you jack/block the tractor too. If you do like I did the first time and put a floor jack under the center of the rear diff like you would do on a car or truck and remove the first tire, the weight of the other side will want to tip the whole tractor to that side and could really throw you off balance - it did for me as I did not know the tires I was removing were loaded to begin with. Either use jack stands or blocks on each side if jacked in the center or use two bottle jacks to raise it so it won't tip to one side. Good luck with your chore !!
   / Handling Filled Tires #18
If the 30 series is like the 40 series you can't do that because you need to spin the wheel, not the disc around. The wheel has a bracket that has two positions. Just turning the wheel around would get the spacing right but it would reverse the tread.
   / Handling Filled Tires #19
you would obviously rotate the tired I would think. This only reverses the thread if you flip the tire over for spacing and keep them on the same side.
Sent from my iPad iOS 6.01 - TNB v1.6
   / Handling Filled Tires #20
yeah.. side to side..
and deffinately DO use plenty of cribbing and jack stands.
DO NOT rely on a single jack pont in the rear!!!!
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2014 Deere 310SK (A57148)
2014 Deere 310SK...
T/A Utility Trailer (A56858)
T/A Utility...
2014 Sun Coastal 16' Cargo Trailer (A57148)
2014 Sun Coastal...
2017 INTERNATIONAL LF687 DAYCAB (A58214)
2017 INTERNATIONAL...
2007 Honda Odyssey Van (A56859)
2007 Honda Odyssey...
