H120 Loader Installation
   / H120 Loader Installation
Beenthere, I meant to put "in the garage"! That's where I parked it for the night since it's level so I can check the hydraulic fluid when the tractor's cold before I use it again. I've heard that's the best time to check it - before use. The up - down and curl are working correctly. Also, I was at low RPM when I heard the noise, so I'll run it higher next time I use it and see if it's still there.
I didn't think about the reduced slip on the front end. I've got a 4ft box blade on the back for a counterweight and my neighbor mentioned adding antifreeze to the rear tires. I didn't get a chance to use it yesterday, so maybe after a little more use, any air that may be trapped can work its way out. I appreciate all the feedback and advice. I'll keep yall updated.
500BBL WHEELED FRAC TANK (A58216)
500BBL WHEELED...
2802 (A58376)
2802 (A58376)
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58216)
2014 AMERITRAIL...
1994 Chevrolet Silverado Suburban (A57148)
1994 Chevrolet...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Crane Truck (A56858)
2015 Kenworth T880...
