GT2550 Deck Rubbing
   / GT2550 Deck Rubbing #1
thetreed1
Hello All,
I have recently re-attached my mowing deck after the winter season and have run into a problem. The arm that is used to add/remove to tension the PTO belt at the mowing deck is now rubbing on the tires when the deck is fully raised. I have my chains on still, but I had them on last year w/o any problems. The part that is rubbing is where the spring connects. I have taken the deck on and off several times to see if it was something I did, to no avail. It does appear that the right hand lift mount (for a lack of a better description the thing with the pin in it), is bent backwards only slightly.
My questions are:
Should I be able to run the mower with the chains on?
What else should I look at on the deck?
Is there anyway of moving the deck forward away from the rear tires?
TIA,
Tim
2022 Jeep Grand Cherokee SUV (A48082)
2022 Jeep Grand...
2013 Nissan Armada SUV (A50860)
2013 Nissan Armada...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2013 Freightliner M2 106 Water Truck (A50860)
2013 Freightliner...
2017 Nissan Juke SUV (A48082)
2017 Nissan Juke...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A51039)
2020 New Holland...
