"Grinding" pavement (black top)
   / "Grinding" pavement (black top) #11
Another thought if you know someone that you can get to bring in a small dozer or similar tracked equipment you may be able to get it churned up enough to spread. We crush our asphalt to 1 1/2" same as 304, we get $6.00 a ton for it.
Randy
   / "Grinding" pavement (black top) #12
if he has a tiller.. just till it up.. don't go too deep.. then compact.. and seal then sand-top it..
OK, this may be crazy, but I'm not the craziest person on this planet, so I figure if I can think of doing it someone else has already tried.
A friend has a dried up asphalt driveway that is cracked and crumbling.
I have a Harley Rake, so....
We were wondering if it would be "practical" to grind up this very dried out black top, compact it either with a vibrator or roller, then tar over it.
I know they do roads this way and I know it is much larger scale equipment, but he has more time than money and I can spare some of my time to help him out.
It is SO dried out that I don't think there is much chance of us just making a tarry mess, I think it will crumble.
Option B would be to dig it all up and have it hauled off, but he doesn't have budget for what we assume disposal costs would probably be.
Your thoughts, suggestions, recommendations are welcome - - ridicule and derision too, we may need to be laughed out of trying this one (-:
BTW, my Harley Rake has a good few hours on it so we wouldn't be abusing NEW equipment, not that I want to wreck it.
   / "Grinding" pavement (black top) #13
Asphalt milling machines are heavy, massive with a lot of horsepower. You will tear up your tractor and Harley rake if you proceed.
   / "Grinding" pavement (black top) #14
I've never run a Harley rake but I know they are expensive and made for dirt. It's your equipment but it sure sounds like you are the one that takes the lose if things go bad.
MarkV
   / "Grinding" pavement (black top) #15
if the asphalt on that drive is truly crumbled.. he should have no problem. most asphalt drives have thin surface course.. that.. and if already broke down.. he can just mix a couple inches deap to get a lil subgrade mixed in. use slowest groundspeed gear. i've done exactly this setp on a drive at my stepdads place. commercial reclaimers and mixers are nothing more than hyge tillers made to go very wide and very deep... neither of which he is doing. also.. asphalt is VERY easy to mix.. unlike concrete or other rock.
I've leave the harley rake at home.. no use for it here. simply mix.. angle or box blade to desired shape.. then roll... then hit with a tack coat or chaipseal.. then sand..
   / "Grinding" pavement (black top) #16
If it is a 1" thick layer of alligatored asphalt then you are probably correct. It could also be nothing more then numerous chip seal coats sold to the homeowner as an asphalt drive. Nothing I have paved is less then 3" in depth...that is what I consider asphalt pavement.
   / "Grinding" pavement (black top) #17
i can sure tell you there are no 3" drive in my area.. heck.. 2.5" on our roads is the norm.. drives.. I've seen them 3/4" ..heck.. I've seen thin 1/2" skims on aprons...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2016 Komatsu PC240 LC-11 Excavator (A59213)
2016 Komatsu PC240...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Tomahawk 42" Skid Steer Pallet Fork Attachment, Asset# 72 (A59076)
Tomahawk 42" Skid...
2022 Ford Explorer 4WD SUV (A56859)
2022 Ford Explorer...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
