Grillo PTO direction...
   / Grillo PTO direction... #1
Bentleg
Bronze Member
BCS 710
I understand Grillo's PTO direction changes when you change directions. Does it turn the same direction as the BCS when in neutral to power a stationary device like a chipper?
Thanks!
   / Grillo PTO direction... #2
You can interchange rear mount attachments like a tiller or a plow between the BCS and Grillo. You cannot interchange front mount attachments like a mower or snowblower. The reverser determines the rotation of the PTO, so you can mount stationary attachments and set the reverser to reverse. Be careful, though. If you forget to set the reverser to reverse, you'll run the attachment backward. I imagine a generator or pressure washer would not like that...
   / Grillo PTO direction... #3
Hi,
I am very new to these forums and to mechanics as well. I was interested in buying a Grillo 110D tractor and BCS flailmower, can i find this "reverser". Is it a special part that can be ordered? [unfortunately, where i live the Grillo importers don't bring the Grillo flail mower].
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
