Grid-tied solar
   / Grid-tied solar #1,111
Here is and article about distributed energy storage. I think that is a beginning of change how we generate and use energy.
Falling energy storage costs and steadily increasing solar capacity stand to catalyze a paradigm shift from net metering to distributed energy storage.
There are no cheap, reliable and safe ways to store commercial amounts of energy. Although there is no shortage of researchers who are happy to take your money, make promises and spend the money tinkering in a lab.
Unless the Almighty adds some new elements to the periodic table. There are no energy density or price break throughs in batteries.
Ever calculate how many golf cart batteries it would take to power NY with just wind and solar power?
   / Grid-tied solar #1,112
Most large utilities that are regulated by states have to offer some version of net metering in the USA.
Thanks Redneck. Are they locked into those rates and if so, for how many years? Enough to give the customer confidence in the payback period required to cover the costs of their installation?
   / Grid-tied solar #1,113
Our utility company buys all its power from TVA. So it has to follow the net metering regs for TVA. And a couple of years ago when I checked on it. They had a 10 year rate guarantee at market price then an additional 5 or 10 year rate at a % of market. I don't remember the numbers but that's the way it was explained to me by the solar people. I couldn't get there numbers to work out though. That was a hands free system. They build you pay. It did have micro inverters and was 50KW. Prices quoted were about 150-160k.
   / Grid-tied solar #1,114
Energy density is only minor issue for stationary use. Life and cost of the storage are the major issues though. The joke is: It can be cheap, reliable and long lasting but you can get only two out of three at present time.
Presently our utility doesn't offer net metering so I am thinking about energy storage. Since the major energy user is our geothermal heat pump I am thinking about storing energy as heat or lack of it. The best solution would be variable speed heat pump with a current sensor on the utility feed line. The power consumption of the HP would then be adjusted such a way that the energy flow to utility will be zero. The HP would heat or cool a large tank with liquid that would be used to heat/coll the house when sun is not shining.
   / Grid-tied solar #1,116
With net metering solar becomes very attractive because the electric company becomes a 100% efficient battery, that's free. Without net metering your kWh prices are going to have to be very high in your area to justify the expenditure financially. HS
   / Grid-tied solar #1,117
Net metering is good for the consumer but it leaves the utility holding the bag. Solar As disturbing to electrical distribution grid operation and generation as it is. It works great compared to wind turbines .
The only place where solar and wind is practical is small users too far from the distribution grid. Or in Hawaii and other isolated regions where generation is $$$ oil fired diesel or gas turbine . Where any power is is better than no power.
Most people don't seem to realize that fossil generation has be kept on spinning reserve to backup solar and particularly wind.
A power plant generating 5% of rated power burns more than 5% of the fuel used at 100% power. Operating costs from wear and tear are not 5% of rated power either. CO2 output isn't 5% either.
   / Grid-tied solar #1,118
Net metering is good for the consumer but it leaves the utility holding the bag. Solar As disturbing to electrical distribution grid operation and generation as it is. It works great compared to wind turbines . The only place where solar and wind is practical is small users too far from the distribution grid. Or in Hawaii and other isolated regions where generation is $$$ oil fired diesel or gas turbine . Where any power is is better than no power. Most people don't seem to realize that fossil generation has be kept on spinning reserve to backup solar and particularly wind. A power plant generating 5% of rated power burns more than 5% of the fuel used at 100% power. Operating costs from wear and tear are not 5% of rated power either. CO2 output isn't 5% either.
I agree, as long as solar remains one or two customers here and there, the electric company will look the other way with net metering and stay in governments good graces. Most electric companies don't offer net metering and those that do will in all likely hood if solar gets to big will drop it, doesn't make sense for them to suppy in essence your battery at no cost. It does seem with some simple weather attention and a record of arrays in their area, electric companies could every easily predict just what there solar customers are going to produce tomorrow and adjust their production plans for tomorrow. HS
   / Grid-tied solar #1,119
No net 10Kw metering according to Hydro One on the 4800V three phase line running past my place to the 2.1MW transformer station 2-1/2 miles away. As it will overload the system.
I can however update my utity service to three phase , 600V and 200amp , 207 KW no problem.
I smell a rat.
The utility courtesy of the rate payer spent over 1 billion last year to subsidize electrical rates for green power . Then turn around and have to pay New York and Michigan to take surplus power on nights and weekends.
   / Grid-tied solar #1,120
927kwh's so far this month. HS
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55315)
2023 New Holland...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2023 Chevrolet Tahoe FL SUV (A55853)
2023 Chevrolet...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
