grease fittings
   / grease fittings #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
I'm looking to get an assortment of spare grease fittings. I have some SAE ones but no metric ones. It looks like most large metric sets come with 6mm, 8mm, and 10mm sizes. Is there one size that's used the most? I would rather not have 50 fittings that I'll never use sitting on a shelf collecting dust. If 6mm is used through out then I'll just buy a couple of 10 packs of straight, 45, and 90 degree.
   / grease fittings #2
I bought an assortment of fittings from Grainger. Wasn't very expensive and now I know I have a good chance of having something that will work. They have a nice online site, easy to find things and order. You can also buy this stuff from Northern Tool, but my experience is Grainger sells a higher quality product and price isn't that different. I've also bought assortment kits of things like O-rings, cotter pins, nuts, bolts, etc. Saves money in the long run because I can finish a project without driving to the store 10 times.
   / grease fittings #3
Fittings on the tractor may not be metric on the implements.:)
   / grease fittings #4
There is also another type of grease fitting base, it is a straight with a slight taper drive in. I am not sure of all of the applications .
Craig Clayton
   / grease fittings
Craig Clayton
I have a grease gun adapter set that includes fitting removal tools and taps. Anything that's driven in I would just tap it to something easier to deal with in the future if possible.
For anything that's not metric, I have a SAE set now. There's a number of fittings that have been in there for decades. I would rather buy a good brand name and only have the sizes I'll most likely need than a cheap Chinese set that includes stuff that'll only come out of the case when it gets accidentally knocked over.
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
John Deere HX15 Flex Wing Rotary Cutter (A50860)
John Deere HX15...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
2019 Chevrolet Colorado 4WD Pickup Truck (A50860)
2019 Chevrolet...
