Snow Equipment Owning/Operating Gravel driveway, snow blower, no cab
   / Gravel driveway, snow blower, no cab #21
Bonjour Max2310
"Without a cabin , hand rotation works OK but if you want power, one cheap way is to use an ATV winch ($60-80) and modify to drive a cable that is wrapped around the snow shute in an endless loop fashion."
Thanks Piloon-- What a great idea to use an ATV Winch. I just ordered one from Ebay $44.95 including shipping. I can't wait to change mine over.
   / Gravel driveway, snow blower, no cab #22
This is my first year snowblowing. I had never snowblowed with anything ever in my life but I knew the plow truck wasn't working for me. I ordered a Pronovost Lynx 70" this fall. It is a great blower & from right there in Quebec!
I have the manual chute rotator on mine. It is the best design I have ever seen but I think I will eventually go with some sort of powered rotator 1. because I plan on making/buying a cab before next year & 2. Because it is kind of akward to turn the crank handle with the blower is down on the ground (bad ergonomics).
It has been a learning experience for me as I have snow blown: dirt, a snow shovel, a wooden pallet, about 25 rocks 1" to 2", & a 5" rock.
I broke 5 shear bolts so far (pallet, shovel, & 5" rock):eek:
I have 1000' dirt driveway. Same thing others said as far as technique, tips, etc..
The Lynx doesn't have adjustable shoes so I made my own for mine.
I want a cab BAD,...mostly because I has a nice heated cab with my plow truck & gave that up for the tractor & because I often owrk out in the cold at my job so I want to be warm when I'm off the clock.
If I were you I'd order a new Pronovost Lynx blower as wide or wider than your tractors rear tires. Made some sort of adjustable shoes for it for next winter (won't need this winter). Buy a cheap snowmoble helmet, a insulated coverall suit, super warm boots, mittens, etc.
Before you pay for your blower check it all over good. I love my blower but they messed up on the auger as it is off by about 1/2" so when you set it flat down on the driveway it goes "whomp,....whomp,....whomp.." as the auger drags on the ground in that one spot.
Good luck & God Bless
   / Gravel driveway, snow blower, no cab #23
I use a blower on gravel with no cab. I wear a balaclava, ski goggles and Santa just brough me a one piece snomobile suite. I stay warm and dry.
Shorten the top link to tilt the blower back a bit and keep it off the ground until you get a good frozen hardpack over the gravel. Then you can drop it down and scrape. Buy a handfull of shear pins and have a look at where they go and how to replace them. Just in case the need should arise on a snowy night.
I do have hydraulic chute and rotation. I find that handy for putting the snow where I want it.
   / Gravel driveway, snow blower, no cab #24
Plowing my driveway sometimes seems to take for ever. I can't believe all the people that think that snow is fun :confused:. Not when it snows every two days, snow banks are 4 feet high, there is barely no more room to put it and winter has not even started yet :eek: (well, now it is)!
I like plowing snow...
Similar wheels would probably be my way to go (and a nice project) but I haven't found a unit yet (all sold out).
So, I made a side panel for my rear blade and decided to forget about a blower -- at least for now...
I know I can weld on the ROPS (as per the manual) but can I drill holes?
This should have read: "I know I can't weld on the ROPS...". Not the same!! And I did drill small holes for some additional work lights.
I Finally bought one but my tractor is gone to the shop and we did get a considerable amount of snow lately :mad:
I was supposed to get an Econor but that's a long story.
This one is a Smyth 54" freshly made in Ontario. It's looks very simple but very rugged! I will try to post pictures in action in a new thread hopefully soon with my impressions. The only experience I have with a snow blower is with a push behind 2811 PowerMax made by Toro that can throw snow up to 45'. I don't expect that much from this new one, can't wait to see ;)
   / Gravel driveway, snow blower, no cab #28
Congrats on the blower.You wont regret getting a blower hope it works out for you.Bummer on the tractor hope it isnt anything major.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2019 INTERNATIONAL...
23105 (A56859)
23105 (A56859)
3079 (A56857)
3079 (A56857)
PALLET OF MISC PARTS & SUPPLIES (A58374)
PALLET OF MISC...
Informational Lot - Shipping (A56436)
Informational Lot...
