Hydraulics newby here. Repeat, newby alert.
Have a used grapple Armstrong attachment which has two 3" bore by 8" ASAE stroke tie rod cylinders. The rod ends are 1.25", and the clevises are threaded.
Grapple manufacturer installed Maxim cylinders. Back in the day and before my time, one started leaking, so prior owner replaced both of the Maxim cylinders with new Cross cylinders. I still have both Maxim cylinders.
This weekend, one of the Cross rod-end clevises snapped. I can thread on the Maxim clevis, but it is threaded slightly "shorter" than the Cross clevis.
I showed this to an experienced neighboring farmer, and he said that grapple would not work correctly with one Cross Mfg clevis and one Maxim clevis because of the 1/4-3/8" difference in how far the rod-end screws into the respective clevises.
I then asked how one got each cylinder connected so that they had same stroke amount while "at rest", and before firing up the tractor. He said to disconnect hoses on the broken clevis cylinder (after de-pressurizing system), then manually pull/push so that I could get the clevis at re-attached, and then when I powered the system would equalize. I wasn't thinking fast enough to ask, "well why won't it compensate for the 1/4-3/8" difference in clevis thread?"
That leaves at least two questions:
1. Is it any problem to install Maxim rod-end clevises on both of the Cross cylinders?
2. How do you get each cylinder connected so that the have the same stroke amount?
Thanks in advance,
Bill
Thanks in advance,
Bill
