Grand L dash (-1, -2, -3) differences
   / Grand L dash (-1, -2, -3) differences #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
Can anyone tell me the differences between the three different 'dash' models for the Grand Ls? I know the -3 has a swivel seat and a different (electric PTO) but that's about all I know. I'm planning on buying a new 4240 but came across a 5440 with less than 20 hours on it for a little less money than new. It's a dash -1. Questions I have are can you tell the year by this and if so when did Kubota switch to -2 and -3? How far does the seat rotate? Is it just for entry and exit or can it turn far enough so you can watch your 3pt hitch, say running a box blade?
I'm not sure if I really need the extra HP but since it's not a larger tractor more HP is usually better (until you go to fill it up). But the 5440 has top n tilt and in the long run could be worth more years down the road if I decide to replace it. I figure tractor year isn't as important as hours and condition.
   / Grand L dash (-1, -2, -3) differences #2
On the -3, they cleaned up the side curtains a little bit to allow the seat to swivel about 15 degrees. The pto is now tied into the anti-stall circuit and you can also get a Kubota backhoe on the GrandL -3.
   / Grand L dash (-1, -2, -3) differences #3
you can get backhoes on the -1 -2 grand L. Its just different mounting frames.
The emmisionaization changed on the -1. They also moved the auto throttle control. I forget -2.. they where only made for a few months, -3 is current, and has the seat changes and PTO sensor.
2001 International 3800 4X2 School Bus (A50860)
2001 International...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
1985 American 48 ft. Dry Van Trailer (A50860)
1985 American 48...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Headache Rack (A50860)
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
