Grading Blade for JD 5045E
   / Grading Blade for JD 5045E #1
tassmannn
Bronze Member
Saint Marks, Fl
1985 Ford F250 6.9 IDI, 2006 Ford F250 6.0 (bulletproofed), JD 5075E, JD 994R, JD 310J (5045Ht054), Kubota RTVX 1100C, CAT D4G, 1954 Ferguson TO30, 2021 John Deere 333G High Flow
Hey everyone. I know I saw one somewhere, but can't seem to find it. I have a John Deer 5045E with the front end loader 553. I have a grapple, Bucket, and fork lifts, but saw there was a grading blade available. I can't seem to find it now. Anyone have an idea of a part number? I tried my local dealer with no luck. I coul get a used bucket, and modify it, but would rather purchase one already made. Any assistance would be greatly appreciated :):thumbsup:
   / Grading Blade for JD 5045E #2
Like a reinforced snow blade? Becareful using one of you find it. The FEL isn稚 designed to shove like that. It痴 can get a scoop of dirt no problem but the arms aren稚 meant for shoving a bunch.
They make a Dozer blade for skid steers. However, I壇 bet you have a 500 series loader so you壇 need the adapter and 3rd function to utilize its functions
Brett
   / Grading Blade for JD 5045E #3
Loaders on tractors are weaker than skid steers & have worse geometry. Tractors are made to pull & a loader is an afterthought bass ackwards impliment. If you want to grade with a tractor, get a box blade, back blade or land plane for the 3pt.
I have used my SSQA snow plow to move dirt. But it was just refilling the trench I had dug with the loose pile next to it. It worked poorly & I was going really slowly. But it was better & faster than using my box blade for the first pass.
   / Grading Blade for JD 5045E #5
If you are lucky your 553 has Skidsteer quick attach meaning finding a blade is easier...if it's the Deere 2 pin system good luck.
I wouldn't waste money on a blade for a loader unless it's only for snow.
   / Grading Blade for JD 5045E #6
Agree with above. Get a blade for the back
Cruise Car Electric Golf Cart (A50860)
Cruise Car...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
