Grab Hooks
   / Grab Hooks #1
Redneck_Randy
Platinum Member
Oklahoma
2005 New Holland TC35A
Picked up a couple cheap grab hooks from the local parts store the other day. Have a friend cutting 2 3"x6" 1/4" thick back plates for the hooks. For now there is no back bracing at all so I won't be using them for now till I get the plates drilled and bolted on. Anyone know where to buy weld on chain grab hooks off the internet?
   / Grab Hooks #2
   / Grab Hooks #3
I got my weld on grabhooks at AW Direct (2nd address in the post above).
They are inexpensive, ship promptly and they are good.
   / Grab Hooks
BIG Thanks for the URL's. :) I swear I tried a Google for weld on grab hooks and just plain grab hoks and found nothing but other then what I just bought. LOL
   / Grab Hooks #5
Those would be slip hooks, I also used the AW direct grab hooks and welded them to the outside edge to take advantage of the strength there. I have a pic in the photo section that for some reason I can't attach here.
   / Grab Hooks #7
bones1 said:
Which would be better for all around use 5/16 or 3/8?
When you are using chain hooks and there are people working in close proximity to them when they are loaded, which would you want?
   / Grab Hooks #8
Most chain binders that you buy that are sized for 3/8" are labeled 3/8 and 5/16 . The 3/8" grab hook is sized to handle either chain.
I would weld on 3/8" grab hooks and then you can use either size chain with your FEL.
   / Grab Hooks #9
I would want gr 70 5/16" chain min. If doin a lot of overhead lifting then I would use gr100.
   / Grab Hooks #10
I got my hooks from AW also and have been extremely pleased with them.
1991 International 4900 Box Truck (A51039)
1991 International...
2014 FORD F-250 (A50854)
2014 FORD F-250...
2013 John Deere 824K (A51039)
2013 John Deere...
2015 John Deere 8345RT Track Tractor (A50657)
2015 John Deere...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
