Govenors on Masseys?
   / Govenors on Masseys? #11
I have never worked on that model, but most have a small plate that is the head of the screen. You take out one bolt and then pull the screen out.
Having a horrible time with internet provider last several days. Takes about an hour to get a post finished ( keeps dropping me off line ) I will check for screen today. Thanks Jerry. Think I will wait for service to improve before next post. Much too annoying.
   / Govenors on Masseys? #13
Diesel Kiki injection pumps are serviced by Bosch. The Angleichung maintains ratio between intake air and fuel injection. Also provides increased torque at lo rpm.
<font color="blue"> The Angleichung maintains ratio between intake air and fuel injection. </font>
Does this mean I should not attempt to make adjustments? Is that not where governor adjustments are made?
When in doubt, I suppose taking it to the dealer would be wise.
   / Govenors on Masseys? #15
I wouldn't suggest that you do anything with it. Think about it this way. It is like the air to fuel mixture on a gas engine (kind of), but it changes the of fuel only (more or less). This is a real simplified version. /forums/images/graemlins/grin.gif
A mechanic I am not. I was mostly just interested whether or not the 1020s were different from other models in regards to unresponsive governors.
But the hydro is an issue I need to resolve. Looking for any and all possibilities before I split the tractor again. Already had it apart twice. Once when I was first trying to find hydro problem and again when the nut on the pinion gear came off. Don't know if factory didn't use locktight but nut came off and the tractor would not move at all. Had to set brakes and drag it into shop. (NO! I didn't have nut off when working on hydro) /forums/images/graemlins/smirk.gif
2392 (A58376)
2392 (A58376)
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
Swict 66" Bucket (A57149)
Swict 66" Bucket...
Fleco Log Forks (A59213)
Fleco Log Forks...
