Gooseneck or stick with bumper pull ?
   / Gooseneck or stick with bumper pull ? #11
Chris, I started with bumper for years. I'm now hauling 11K lb load. I still have 2 bumper hitch light trailers. But for my heavy load, I'll always stay with the GN. Funny how each person's experiences end with different opinions, results. :)
Yea. Pull 15,600# with a tri-axle bumper pull. It tracks great, does not cut into the corners, and handles like a dream behind my F350.
I have had as big as a 25,000# GN and a 24,000# BP.
Chris
   / Gooseneck or stick with bumper pull ? #12
No there's 6000# and 7000# and 8000# single tire 8 lug axles . And ya not losing but 2000# . And really a gooseneck is way safer than a 14000# payload on the back bumper that's plain dangers . Sent from my iPhone 5 using TractorByNet
Really? 14,000# is dangerous as a BP. Lol
You need more truck if you believe that.
Chris
   / Gooseneck or stick with bumper pull ? #13
Chris
Have plenty of truck . And know its dangerous deal on a bumper pull most likely on a receiver hitch . On one little pin . A bumper pull is no where as stable as a gooseneck load . Really dangerous with that kind of weight .
Hope you stay away from me on the road .
Think I have plenty of truck and trailer if need be .
That's confusing - you apparently had enough truck for a 14K BP 18' and now are going down in weight to 12K but up in length to 20+5'.
My M4700 sure fills up my 16+2' Hudson
But it's a pain to try and park with my 20' truck on a narrow suburban street.
If you don't have "parking" problems I'd say go for it.
I pull the 14k with either my Kenworth which cant take a gooseneck hitch,or Chevy 2500 which Ive never wanted to put a gooseneck hitch on.
After digging a little deeper ... bare tractor is shown by kubota specs to be about 2700#. With FEL (1100#) and a bush hog (1000#) on it + loaded tires about 5200#. Add a box blade 500#, and a disk 800#. that's about 6500 # +/~ ... if trailer weighs 4k, that leaves a 8k payload capacity.
Tractor and implements at 6500 # should be fine for that.
My bumper pull is not a deckover and it limits me to a 5' bush hog. Anything wider wont fit between the fenders. My BB and disk are both 8 ft so they wont go on it at all when mounted to tractor. I have to set them on with the loader, then drive tractor on trailer.
With the gooseneck I could step up to a 6' cutter if I chose too and drive on with the disk or BB on the tractor.
The gooseneck over the bumper pull I have now would allow me to carry more implements with it.
Right now if I go to hunting lease 50 miles away.. I have to go one 100 mile round trip with cutter.. do the work, load all up, drive back drop off cutter and load up and return with disk to finish.
Both trailer setups I guess have their positive and negatives.
If the guy hasnt sold it by this weekend I think im going to get it and give it a try... I really don't have to sell the bumper pull. I can keep them both.
   / Gooseneck or stick with bumper pull ? #15
Your wrong on your payload . Because all the trailer weight is not all on the trailer axles . You have more that 8000# payload on the trailer .
If ya have room to keep them both and don't just have to sell the bumper pull . Buy the gooseneck . And go from there . You can always sell one down the road after you see what ya want to keep .
   / Gooseneck or stick with bumper pull ? #16
I've been hauling a tractor, CTL's and mini-ex's with a 14k deckover GN for the last ten years. It's worked fine, but messing with a 20+5 isn't always the best. I got a 14k BP for cheap in the deal with my CTL purchase. For some odd reason, this particular trailer has a 12.5k hitch on it from the factory. As soon as I switch it to a lunette eye/pintle setup, redo the wheel bearings and get it painted up nice it'll be my everyday trailer. It pulls behind my 1 ton just as smooth as my GN does. The GN will probably only get used for hauling 30 foot culvert pipes and round bales.
To say that a 14k BP trailer is somehow dangerous is silly.
   / Gooseneck or stick with bumper pull ? #17
Y'all haven't seen all the wrecks from them heavy loads as I have .that where with bumper pull trailers .
But like said ya just stay away from me on the road . When ya see my front end coming up behind y'all . Pic posted in earlier post . Just stay in the slow lane so I can get around ya in the fast lane.
   / Gooseneck or stick with bumper pull ? #18
Six in one hand, 1/2 a dozen in the other. I have no problem with either. I really do not have a preference as far as gooseneck or bumper pull. A well built trailer will do its job. I prefer a low trailer for equipment. The dual tandem trailer in the pic is nice but I would use the bumper pull for that tractor. There is no such thing as a perfect trailer, but it sounds as if you will only have the one. I would pick the one that is most flexible for all your needs.
Sometimes you don't get your preferences!
   / Gooseneck or stick with bumper pull ? #19
I prefer a gn for equipment. But make sure wherever you are towing to and from has adequate room for maneuvering and a wide approach for the drives. Gn's cut corners really short.
   / Gooseneck or stick with bumper pull ? #20
What was the cause of the wrecks? Did the 'one little pin' break? After all, only 'one little pin' holds the trailer to a big rig and every fifth wheel trailer.
Hauling safely starts with the right truck, with a safety minded driver, the right sized (not type) hitch, hauling the right trailer that's properly loaded.
2014 Ford Escape S SUV (A48082)
2014 Ford Escape S...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2011 Ford Flex SUV (A50860)
2011 Ford Flex SUV...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
