CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 5,776
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I have a SL&H Hurlimann 435 Prince with a Mitsubishi 4 cylinder engine.
The tractor is equipped with an "auto-magic" glow plug timer control. Timing starts when the ignition key is first turned. There is a status display on the console.
However, in cold air (Vermont in winter) the heating timer is woefully inadequate.
A cold start at temps between 10 and 25 F requires activation of the timer at least five times prior to energizing the starter.
Warm weather starts are fine.
I have fitted a block heater to pre-warm the engine. With a half hour plugged in preheat, the engine starts right off with a cycle or two of the glow plug timer.
I'm thinking I would like to do away with the "auto-magic" controller and control the glow plugs via the key switch (it has the "turn counter clockwise: contacts), or fit a "press to energize" button on the dash panel.
Any thoughts on the reversion of modern automation to old school control it your self?
I'm thinking a 40 amp relay to carry the glow current would be enough.
