Getting an L3800 HST shop manual from Messicks
   / Getting an L3800 HST shop manual from Messicks #11
DT - Dual Traction, ie. 4 wheel drive... Ok, more appropriately front wheel assist.
Kubota designations:
BX Series
V = Loader Valve
T = Turf Tires
R = R4 Industrial Tires
LB-T = Loader Backhoe w/Turf Tires
LB-R = Loader Backhoe w/R4 Tires
B Series
E = Two Wheel Drive DT = Dual Traction 4wd
HSE = Hydrostatic Transmission, 2wd
HSD or HSD-1 = Hydrostatic Transmission, 4wd
HSDB = Same as Hydrostatic 4wd, but includes Bi-Speed turn
HSD-T = Hydrostatic Transmission, 4wd, Tow Tractor (Airlines)
TL = Tractor, Loader
TLB = Tractor, Loader, Backhoe
L Series
DTC = Dual Traction, 4wd, Two stage clutch, Live continuous Running PTO (L235/L275) DTC = Dual Traction, 4wd, Integral Factory Cab (L3600/L4200) DTN
DTS = Dual Traction, 4wd, Power Steering
DTSC = Dual Traction, 4wd, Power Steering, Two stage clutch, Live continuous Running PTO (L235/L275)
DTN = Dual Traction 4wd, Narrow Specialty Tractor DT-W = Dual Traction 4wd, (W) Wet Clutch = EVER CLUTCH
F = Two Wheel Drive
FS = 2wd, Power Steering
FC = 2wd, Live-continuous running PTO
FSC = 2wd, Live-continuous running PTO, Power Steering
FST = Fully Synchronized (Main) Transmission
GST = Glide Shift Transmission
GSTCA = Glide Shift Transmission, 4wd, Factory Cab, "A” is for Air Ventilation Kit (L3600/L4200)
GSTC = Glide Shift Transmission with Integrated Factory Cab
HC = High Clearance (L245HC only)
HF = Hydraulic Shuttle, 2wd
HDT-W = Hydraulic Shuttle, Dual Traction 4wd, (W) Wet Clutch = EVER CLUTCH HDT = Hydraulic Shuttle, Dual traction
HSTC = Hydrostatic "Feather Step” Transmission with Integrated Factory Cab MF = Mechanical Shuttle, 2wd
MDT = Mechanical Shuttle, Dual Traction
SS = Shuttle Shift
T = Tow Tractor
W = Wide tread for Row Crop applications. (i.e., Tobacco)
DTC = Dual Traction 4wd, Cab Model
DTCCS = Dual Traction 4wd, Cab with Creep Speed
M Series
DT-1 = Dual Traction 4wd, ROPS model with IC/Shuttle Transmission (M7580/M9580)
DTL = Dual Traction 4wd, Low Profile (for orchards)
DTM = Dual Traction 4wd, MUDDER (for specialty, row crop and vegetable)
DTN = Dual Traction 4wd, Narrow (for vineyard/orchard tractor)
DTN-B = Dual Traction 4wd, Narrow wheel tread with Bi-Speed Turn
F = Two Wheel Drive
F-1 = (-1) = Larger two pump hydraulic system
FC = Two Wheel Drive Cab Model
F-CS = Two wheel drive with Creep Speed (Ag. tires or as Turf Special)
HC = High Clearance (2wd M7950 only)
HD = Hydraulic Shuttle, 4wd
HDC = Hydraulic Shuttle, 4wd, Cab
HDCCS = Hydraulic Shuttle, 4wd, Cab, Creep Speed
L = Low Profile
ML = Mechanical shuttle, Low profile
MDT = Mechanical shuttle, Dual traction 4wd
MDTL = Mechanical shuttle, Dual traction 4wd, Low profile
MF = Mechanical shuttle, Two wheel drive
OC = Orchard model
S = Synchro-Shuttle, 2wd
SD = Synchro-shuttle, 4wd
SCS = Synchro-Shuttle, 2wd, Creep Speed
SDN-B = Synchro-Shuttle, 4wd, Narrow with Bi-Speed Turn
SDNBC = Synchro-Shuttle, 4wd, Narrow with Bi-Speed turn, Cab model
SDNBF = Synchro-Shuttle, 4wd Narrow with Bi-Speed turn, Foldable mid-mounted ROPS
SU = Special Utility, 2wd
SU-R = Special Utility 2wd, Rigid ROPS
SU-F = Special Utility 2wd, Foldable ROPS SU-TF = Special Utility 2wd, Turf Special
SUD-R = Special Utility, 4wd, Rigid ROPS
SUD-F = Special Utility, 4wd, Foldable ROPS
SUMDT = Special Utility, Mechanical Shuttle, 4wd
SUDT = Special Utility, 4wd
W = Wide Row
H = 2WD, ROPS (Note: All H-Models are Std. Swing Shift 16F X 16R speeds)
HC = 2WD, CAB
HD = Swing Shift, 4WD, ROPS
HDC = Swing Shift, 4WD, CAB
DS = Dual speed, ROPS (Note: All Dual Speed models are 32F X 32R speeds)
DSC = Dual speed, CAB
SDSCC = Dual speed, CAB, cold weather w/high amp alternator and creep speed and second remote valve
SDSC = Swing Shift Dual Speed, CAB DSDF = Dual Speed, 4WD, ROPS
SDSL = Dual Speed, 4WD, Low Profile
M-Series Notes:
Suffix "1” models are the second generation "Wide” Cab tractors. Cab is 5.7 inches wider than first models.
Suffix "2” models are factory equipped with 540 / 1000 RPM PTO kits. M95S and M105S:
The "S” represents the model/tractor class in general is no specific meaning, however it can be applied to "Swing Shift” as the base transmission on all "S” models.
M50-Series 1983 - 1984 Cab was orange in color, air conditioning was optional.
   / Getting an L3800 HST shop manual from Messicks #12
ljohnson, I thought I saw 'Dual Traction' somewhere, but couldn't find it.
Thanks for the info.
   / Getting an L3800 HST shop manual from Messicks #13
It is definitely "Dual Traction" as it says on my operators manual. But that manual is not very helpful. Back to the original question, where to get a fair priced repair/shop manual for a L3000DT. Any one found one yet?
   / Getting an L3800 HST shop manual from Messicks #14
When I bought them in the past I got the best price from a mail order dealer.
If you happen to buy any parts manuals, it's an eclectic experience. Some models seem to have them while a closely related model may not. The only parts manual I could get for my M8950 was a cab model yet the majority of tractors were open station. While I bought the "wrong" parts manual just to have something, it failed to cover the model I had. Beats me.
   / Getting an L3800 HST shop manual from Messicks #15
ljohnson--Let me compliment you on the excellent detective work regarding the Kubota model designation a couple posts earlier. I don't think any other maker has made so many models and so many changes.
   / Getting an L3800 HST shop manual from Messicks #16
I highly recommend Lashley Tractor. They have conistantly
been cheaper on price on everything I have checked. Additionally
so long as an item is not "wholegoods", if it is over $50.00 the
shipping is FREE. I usually hunt down a guy there named Tracy.
Please tell him Hello for me.
   / Getting an L3800 HST shop manual from Messicks #17
WOW!
Post #11 should be a sticky!
Nice Job!
   / Getting an L3800 HST shop manual from Messicks #18
Thanks... I'd love to take credit, but it was posted on another forum by a Kubota tech. Came across it when I had my M6040 and hung on to it for reference.
   / Getting an L3800 HST shop manual from Messicks #19
This is an old post, but thought I'd offer the part number for the L3800HST as I just ordered one:
9Y121-05200
Regards,
Mark
   / Getting an L3800 HST shop manual from Messicks #20
Is that part # for the 4x4 model? I've been meaning to buy one.
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A52709)
2019 KOMATSU...
PALLET FORKS (A58214)
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A58018)
2013 KENWORTH T680...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
