generator heads
   / generator heads #1
gws
Platinum Member
yanmar ym1810
Has anyone used this harbor freight generator head http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=45416
or ther northern head? http://www.northerntool.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=6970&productId=21008&R=21008
The northern head says for horizontal application, what plane of the generator is horizontal? the base plate or the body? It also says it turns clockwise or counter clockwise. I take that to mean power is generated no matter what way I turn the generator shaft?
Any easy way to get a vertical shaft motor to drive a horizontal shaft device? Any right angle differentials that are cost effective for this type of application?
   / generator heads #2
The shaft should be horizonal, and CW and CCW does mean that it will make power in both directions.
   / generator heads #3
WELL IF YOU TURN IT ccw THE CLOCKS IN THE HOUES WILL GO BACK WARDS AND YOU CAN GO BACK IN TIME AND BUY THE WINNING LOTTERY TICKET /forums/images/graemlins/smile.gif
OOOPS DANG CAP LOC KEY
ok horzintal is same as a floor in the house ground, vertical is up & down.... there was a thread started here about 10 months ago that had a bunch of info & build up using the harbor freight unit... do a search for it and you will gets lots of info.
Makrm
90018 (A48082)
90018 (A48082)
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
UNUSED Plastic Mesh Safety Fencing Roll (A50860)
UNUSED Plastic...
Cat 60" Wheel Loader pallet Forks (A49461)
Cat 60" Wheel...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
