gear ratio help please
   / gear ratio help please #1
gochenour799
I need help calculating a reducing gear ratio. Example.. I have a gasoline motor I want to run @ 2000 rpms and a pump that needs to be run a 1250 rpms so I need to reduce the out put by putting a small gear on the motor and a larger gear on the pump , with chain in-between them . I can't figure out how to figure the size of the gears . Say 10 teeth and 20 would that be 50% reduction ?
   / gear ratio help please #2
2000 divide by 16 times by 10 = 1250.
So you'd need sprockets of 10 and 16 teeth for the motor and pump respectively.
Wow that was fast ..... THANK YOU so much for the reply..
   / gear ratio help please #4
1250 divide by 2000 = .625
10 divide by .625 = 16
   / gear ratio help please #5
A 10 tooth pinion is kinda racy. Try a 20 tooth pinion & 32 tooth gear.
   / gear ratio help please #6
or a 15 and 24 :D
   / gear ratio help please #7
Don't know if you've shopped for sprockets yet, but here are two places I've used that have good prices:
www.thebigbearingstore.com, click on "roller chain" to get to the sprockets link. They also have lots of inexpensive bearings.
BMI Karts and Supplies - Home, basically go-kart stuff but they have lots of big sprockets.
Ok thanks everybody... I think I will idle the motor down to 1950 rpms and run a 25 / 16 that will give me 1248 rpms on the pump .
.1950/25x16=1248 ... the reason is I already have these sprockets...and if I need more I can just bump the idle up on the motor .
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2842 (A54756)
2842 (A54756)
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
