Oil & Fuel GC2300 Fuel Shut off relay part number
   / GC2300 Fuel Shut off relay part number #11
Okay after looking at the thing for an entire weekend I am no further ahead than I was. One weird thing is I found 2 circuits wired incorrectly at the fuse box [direct from the factory] while I was checking the wiring using the wiring schematics. I chased every wire associated with the fuel stop relay and solenoid [looking for a short] and found nothing and checked pretty much the rest of the harness as well for shorts. I removed the solenoid and bench tested it. After a few cycles it felt warmer than I thought that it should. I cleaned it up really good and cycled it manually a bunch of times to make sure that it moved freely. I couldn't amp test it because I don't have a DC amp meter. I tested the solenoid plugged back into the system but not installed. The solenoid worked fine and the relay worked as designed with a few second delay before the solenoid went to the pulled back position. I reinstalled it and started and stopped the tractor something like 5 times and it's working okay for now, but I don't know why or when it will blow the fuse again, when the fuse does blow it blows as if a short happened with the wire completely gone. I will keep an eye on it and see what happens. I'll post if anything changes.
   / GC2300 Fuel Shut off relay part number #12
That certainly sounds frustrating.
Please keep us informed.
   / GC2300 Fuel Shut off relay part number #13
It's been awhile now [many start/stop cycles] that the fuse has blown. I have the fuse for one of the mis-wired circuits pulled and as of now the fuel slenoid fuse has not blown. I think there may be a short between the utility circuit and the fuel solenoid circuit but don't have the time to take the tractor down again [winter is coming] so as long as I keep the fuse out it appears that the fuel solenoid is good to go. I will update if anything changes.
   / GC2300 Fuel Shut off relay part number #14
Perhaps you should rewire it this winter, with heavier wire and then a bigger fuse?
CAT IT18 (A55272)
CAT IT18 (A55272)
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
Giyi Mulcher (A57149)
2017 Takeuchi TL12R2 Track Skid Steer, S/N 412100259, Kubota Diesel Engine, Joy Stick Operating (A59076)
2017 Takeuchi...
2022 INTERNATIONAL MV607 (A58214)
2022 INTERNATIONAL...
