5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,595
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Usually, once a radial seal starts leaking, they don't quit leaking until replaced. The other issue is how the front axle is vented and if that vent is plugged with trash. The axles have to breathe (either by dead air space above the lubricant) or via a to the atmosphere vent or the axle will become pressurized as the lubricant warms up. Why the differentials on your car or truck have a vent hose on them. If they weren't vented to the atmosphere, the outboard axle seals would leak. In reality the radial seal on each outboard has a very small contact area so any vertical movement in the outboard can cause the seal to weep lube oil. I've replaced a number of them on my large Kubota's and in every instance, the kingpin bushings were shot which allowed the vertical movement of the outboard. Easy to replace to the correct sized bushing driver or appropriate size socket and hammer and remove the worn ones is a simple matter of driving them out with a punch.
