Gas line anti-freeze
   / Gas line anti-freeze #1
RichZ
White Creek, New York, Washington County, on the V
Kubota 4630 with cab and loader
Is there any difference in different gas line anti-freeze? I notice the ones with methyl alcohol are cheaper than isopropyl alcohol. Is there any difference? Is there anything besides the alcohol in them? Could you just buy bottles of isopropyl rubbing alcohol and use that, since it's cheaper? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Gas line anti-freeze #2
Napa makes a product called Thermo-aid, we have used it with great results,think its about .90 a bottle. Buy it by the case, you will like it. Just dont forget gasoline engines only- /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Gas line anti-freeze #3
I have learned that methyl alcohol-based dry gas is not recommended for two-strokes, but that isopropyl alcohol-based dry gas is OK. Methyl must affect the lubrication qualities of the oil burned in a two-stroke, my snowmobile owner's manuals all warn against this.
Regarding using rubbing alcohol, I'm guessing it could be a substitute for dry gas but would require higher quantities and/or be more costly. Typically anything fit for human consumption is refined to a higher level and/or less potent than the non-human equivalent. It would be interesting to compare the active ingredients of the two my bet is dry gas is a lot more potent than rubbing alcohol.
   / Gas line anti-freeze #4
Also, typical "rubbing" alcohol is a solution of isopropyl alcohol and water. Putting that in your fuel tank might be counter-productive. /forums/images/graemlins/wink.gif
   / Gas line anti-freeze #5
The rubbing alcohol I have seen is either 70% or 95% isopropyl alcohol with the balance being water. Either way the water absorbing properties of the alcohol has been reduced. I know pure 100% isopropyl is available in five gallon cans which we use as a cleaning fluid, but not sure where we get it.
Yikes!!! I didn't know that rubbing alcohol had water in it!!! Forget that idea!!!
But I still wonder if there's a differnece between isopropyl or methyl alcohol for water absorbtion.
   / Gas line anti-freeze #9
The whole idea behind alcohol as a de-waterer, is that water is a polar material, and alcohol is a polar solvent..( gas and water don't mix..yada.yada..alchohol and gas does.. and alcohol and water does... ) once the water is solvated.. it isn't sitting in a glob at the bottom of the tank, or in a line, etc.. but is free to pass into the combustion chamber... etc.
For a neat trick, get a small glass of gasoline.. add a small amount of water... it puddles to the bottom. Add some alcohol... let sit, or agitate.. observe...
As other pointed out.. on the shelf alcohol is already some percentage an aqueous soloution...
Soundguy
   / Gas line anti-freeze #10
Better experiment........ put the container contents of the dry gas into a 4 cup measuring cup and note the amount. Fill the dry gas container to the same level as the dry gas was with water and pour that into the measuring cup and see how much of the total amounts of liquid now measure...... Hope that these instructions are clear to you......... 8 oz of dry gas + 8 oz of water = ___ oz ?? post your answer and then do the experiment......
2010 John Deere Gator UTV (A49461)
2010 John Deere...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
Ford NAA Jubilee Tractor (A51039)
Ford NAA Jubilee...
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
