Garage for Power Trac and Shop
   / Garage for Power Trac and Shop #71
Fourteen is correct. My small shop is insulated and heated with a small infrared propane "Mr Heater". Keeping the shop above the dew polint and above freezing allows you to keep your tools rust free but also allows you to keep fluids without worry. My PT stays in a covered area without heat and it does get wet with dew - guess my next project is to build an additon to my barn.
   / Garage for Power Trac and Shop #72
Just a quick point: a dehumidifier will cost more upfront, but it requires less energy to run that a heater.
If you do go the electric heater route, try to get a ceramic heater, which is much less likely to ignite fumes or dust.
Don't over look the possibility of using solar heat.
Solar garage heater
It is an old article, and some scrouging is involved, but the price is tough to beat.
All the best,
Peter
Solar garage heater
All the best,
Peter
Peter, I would love to do a solar heating system, but I live in a valley with trees all around. I would have to cut down many trees and get divorced to do this. The divorce alone would cost more than heating the garage with electric heat for decades. I would also miss my wife.
Thanks anyway.
   / Garage for Power Trac and Shop #75
Thanks Farm23! You are absolutely right! That is the wisest statement that I have read here on TBN in nearly four years! I wish others would realize how true your statement is!! If I were to send you my wife's cell phone number, would you call her, and show her the error of her ways?? In the last 38 years she has actually (a few times) questioned my vast knowledge, veracity, and humility!!! Perhaps, with your help, we could purge any lingering doubts from her mind!!!!
Thanks, again!
PS: A 220 volt heater is much more energy efficient than a 110, because it provides a balanced load.
That solar heater is too ugly, too much work, and only provides heat for 5 daylight hours. The need is for just low, constant heat, particularly overnight, to keep the tools and equipment above the dew point.
I happily keep my Morton (R19 walls & R38 ceiling)at a minimum of 55 degrees 24/7/365, yet seldom hear the heaters run. (Mostly just on cold days after I have opened the OH doors for some reason.)
I use two of these heaters Portable Electric Garage Shop Space Heater Model BRH562 - eBay (item 200186716018 end time Jan-04-08 07:57:37 PST) , hard wired. One is set at 55 and left on all the time. The second one is set at 70, and is only turned on when I will be working inside for an extended period.
   / Garage for Power Trac and Shop #76
Didn't you mean to say humidity instead of humility.:p
Here in the Great Pacific Northwest, where it's been known to rain some, keeping out buildings above the dew point goes a lonnnnnnggggg way towards keeping tools and what not from getting soggy and or rusty.
FOURTEEN said:
Thanks Farm23!
Fourteen, I agree with everthing you said except that 220 volt heaters are more efficient. Electric heaters are all 100% efficient. All of the losses in an electric heater (in the cord, wiring, switches, fans) convert to heat and since heat is what you want then the losses are not losses. Having a balanced load is good, but it does not help efficiency. Having lower current in the lines from 220 volts will reduce losses in the power lines leading to the garage, but that will be pretty small. If you want to count this, then maybe you are right.
I think the dehumidifier is the best choice. Again all of it's losses turn to heat (a good thing as you stated) and humidity is removed (also a good thing). The negatives are more initial expense and more maintenace. It might be good to put in a small base board heater as a backup to run at low temperatures. I am very sensitive to energy cost since my house is built of insulated concrete forms with R50 in the walls and R55 in the actic. We pride ourselves on low electric bills, so I hate to use much electric heat. Even the dehumidifier is more than I want to run. Oh well, my tax increase will probably be more than my electric bill increase and that is worse. Although it is better to send money to the county then to the Arabs.
   / Garage for Power Trac and Shop #78
No, that is not what I am referring to. I am talking about saving money on your electric bill. The residential single phase electric power meter measures the maximum current flow through either the red or black sides of a 220V service.
One 220V/2200W heater will draw 10A on both sides. One 110V/1100W heater on each side (balanced) will draw 10A on both sides.
One 110V/2200W heater will draw 20A on one side. Two 110V/1100W heaters on one side will draw 20A on one side.
Therefore, if the load is unbalanced, the meter will 'see' more current flow and charge more money. On commercial and industrial three phase systems much time and effort is used to design balanced systems to reduce electric cost.
I always wanted to build one of those foam form houses, but didn't have the opportunity! With the possible exception of the 'nut house', this will be my last residence. I bought it used, so I had to take it 'as built'. I've made quite a few improvements and changes, but using foam forms isn't an option!!
   / Garage for Power Trac and Shop #79
My understanding is that residential electric meters measure wattage used. A 110 V heater using 10 amps uses 1100 watts per hour. A 220V heater using 5 amps uses 1100 watts per hour. The same wattage for the same cost.
But--even if you were correct the problem could be solved by connecting the two heaters to circuits connected to different sides of the bus in the distribution panel.
   / Garage for Power Trac and Shop #80
Although I have heard that a balanced system is ideal, it will be darn hard to achieve. If I remember right, there was an electric company in town that advertised that they could balance the electric panel. I am assuming that they were trying to balance out the 110v breakers on each side, because the 220 v breakers are already balanced. I would say in most situations, you are never balanced.
I am sure that some electrical guru will chime in here and set us straight.
2006 Ingersoll Rand P185 Towable Air Compressor (A55851)
2006 Ingersoll...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A55852)
2016 Peterbilt 579...
2019 Yongfu Scooter (A55853)
2019 Yongfu...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
2013 TAKEUCHI TL10 SKID STEER (A52707)
2013 TAKEUCHI TL10...
PULL BEHIND PADFOOT COMPACTOR (A52707)
PULL BEHIND...
