Stampeder
- Joined
- Dec 2, 2006
- Messages
- 318
- Location
- East Texas
- Tractor
- Montana 4940C, FEL, Quick change 3 point factory hitch, pallet forks, grapple, 50 gal tank sprayer, Bush Hog PHD
So I came out the other day to start my Montana and it wouldn't start.
It had run just fine the day before.
I thought it might be a fuel filter issue so I changed that. Primed it up no problem. But still no go.
I checked the 10 amp fuse for the fuel shut off valve and it was fine. Tested it with an ohm meter.
I then checked the bleeder valve on the injector pump. It flowed without any bubbles.
When I cracked the nut on top of one of the injectors no fuel would come out. Nothing....
This leads me to the question of where is the fuel shut off valve located? I want to check the wiring to it to confirm that it has good connection and see if it is getting 12 volts.
I've looked through my manuals but I don't see any pictures showing where it is located.
Can anyone enlighten me?
Thanks a lot.
Glenn.,..
Thanks a lot.
Glenn.,..
