Fuel gauge reads empty but half tank remaining
   / Fuel gauge reads empty but half tank remaining
I don't use bio diesel as mm HD I have only filled with a small battery powered pump.
I'm going to call dealer since it is still under warranty.
   / Fuel gauge reads empty but half tank remaining #13
What model tractor and how is fuel tank made? My M6800 has the saddle fuel tank with float level on only one side. Going one direction around a slope I have 1/2 tank, coming back my fuel light comes on. I have been planning to put a one-way flow valve in the line at the bottom of the tank compartments.
   / Fuel gauge reads empty but half tank remaining #14
Other than "on the road vehicles", I've never found that the fuel gauges were overly accurate. My solution - fill your tractor fuel tank after each and every use.
Under the heaviest use - I'll consume about 1.75 gallons per hour. I've never had a project that is continuously long enough to even get close to running dry on fuel. So.........the fuel gauge, accurate or not, is of little use to me.
This solves two concerns - the fuel tank is always completely full whenever I start the tractor. With a full fuel tank I've never had problems with condensation and water in the fuel.
2018 Land Pride RCR1260 (A53317)
2018 Land Pride...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A55852)
2013 Ford F-450...
Chevy caprice (A55758)
2006 Peterbilt 378 Wet Kit Tri-Axle Day Cab Truck Tractor (A55852)
2006 Peterbilt 378...
Massey Fergusson 4710 (A53317)
Massey Fergusson...
2016 Kawasaki Mule (A55973)
2016 Kawasaki Mule...
