Fuel and water temp gauge not working.
   / Fuel and water temp gauge not working. #1
JSanders10
South Alabama
'98 MF231, MF451
On my Massey 451, the fuel gauge and water temp gauge are not operating.
When I crank the tractor they both move only slightly from the far left position, like a hair or about 1/16". Not much. Doesn't appear to be a fuse, all my fuses look fine.
Ideas?
   / Fuel and water temp gauge not working. #2
I don't know your tractor specifically. I do know that on some vehicles (especially older ones) instruments do not operate on twelve volts. There is a voltage regulator dedicated to these instruments, frequently limiting them to about five volts.
   / Fuel and water temp gauge not working. #3
Most variable instruments have a constant 12v power and a variable ground signal. Check your ground connections.
   / Fuel and water temp gauge not working. #4
Yep, a lot of gauges function with a variable load to ground. Usually these grounds run through the sensor/sender and then goes to the closest convenient ground (could be the engine block in some cases), but sometimes they run back to a common ground location.
When I see multiple unrelated gauges fail, I think that either the shared +12V feed has an issue, or a common ground point has an issue. Both should be very obvious upon examination. From what you describe, I'd be inclined to investigate the ground.
   / Fuel and water temp gauge not working. #5
IF you gauges are mounted to printed circuit board (modern tractors) check connections to board from sensors and check how tight (or corroded) screws are to connect gauge to PC board... Had loose screws on my temp gauge straight from manufacturing...
Dale
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2014 Ford Escape S SUV (A48082)
2014 Ford Escape S...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2022 Club Car...
Honda Foreman ATV (A50860)
Honda Foreman ATV...
