Frozen Nuts
   / Frozen Nuts #11
I'm eager to hear if the wax trick works. Usually if a stuck nut or bolt even remotely tries to tick me off, on goes the air compressor and out comes the impact. :) With those blade nuts, they are torqued pretty tight to begin with, and the buildup of grass and whatnot makes them extra difficult to break free. Nice thing with impact is it will direct the force at the nut without turning the spindle, which makes it so easy.
If the wax doesn't work, go to Sears and get a long 1/2" drive breaker bar.
-Fordlords-
   / Frozen Nuts #12
The only decks I've seen with left hand threads discharged on the left hand side. I think the design always puts the rotation in a direction that would tighten the blades, otherwise, blades would be flyin everywhere!
Curt
   / Frozen Nuts #13
I have the same problem. The nuts get so tight I couldn't remove them. My dad has an impact wrench so now it's not a big deal anymore but before I couldn't budge them and had to take it to the dealer to loosen. What a pain!
Michael
   / Frozen Nuts
Exactly right, you want the blade rotation to tighten the nuts if anything.
You know what's confusing? Bike pedals. One has right hand thread, one left hand so the pedals can't loosen when pedaling. Every time I go to remove them I scratch my head trying to get straight which is which.
   / Frozen Nuts #15
I always use a 1/2" wrachet with a 3' piece of black pipe over the wrachet to use for leverege. It always works for me. Also, I spray WD-40 on my mower deck nuts before I put them back on. Good Luck.
   / Frozen Nuts #16
You have a very good ratchet. We have broken many ratchets doing this. We use a breaker bar now with a pipe on it.
   / Frozen Nuts
Well I tried the wax trick and it didn't work - but I rushed it so it really wasn't a fair test. Heated the nuts, melted some wax into them, reheated, melted some more. I know it sounds foolish but I couldn't wait a half hour, tried them after only a few minutes, no luck. I popped the deck back on and mowed, needed to get it done this afternoon.
I'll give it another try. If no luck I'll bring the deck to a guy who has an impact wrench, once I get them off once I'll be OK for the next time.
   / Frozen Nuts #18
I think the bike pedal threads are the same as mower blades, forward pedal tightenes them, so the left would be left handed and the right would be right handed?
I always apply a liberal amount of grease on the threads of the blade spindles before putting the nuts back on, it seems to reduce the corrosion and helps on the next removal.
Curt
   / Frozen Nuts #19
I actually use Locktite on blade nut's/bolts. It may seem dumb to use something on them that would make them even harder to get off but the opposite is true. Use the general purpose / light duty blue Locktite. It completly seals the threads and prevents water/moisture from entering and rusting them up which is the whole reason they are hard to get off in the first place. You will be amazed how much easier they are to remove next time.
   / Frozen Nuts #20
I always used Never-Seize on my push mower. Put it on the Cub, hopefully i'll help.... although I did buy an electric impac, so I'll probably never know.
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
(APPROX.52) UNUSED 2X4X16 PRIME GRADE LUMBER (A57192)
(APPROX.52) UNUSED...
WHIRLPOOL REFRIGERATOR (A57192)
WHIRLPOOL...
2009 Ford E-350 Cargo Van (A56858)
2009 Ford E-350...
Swict 8' Fork Extensions (A56469)
Swict 8' Fork...
TCM FD30T6T Forklift (A55973)
TCM FD30T6T...
