Front End Gear Oil
   / Front End Gear Oil #1
sailorman3
Bronze Member
Newfoundland
Kioti CK3510
I am unable to get SAE 90 gear oil in my location. What is the next best gear oil to use? I would prefer to change it out from hydraulic oil. The tractor is a CK3510. Thanks.
   / Front End Gear Oil #4
I also changed out the multi purpose tractor fluid for gear oil in my last 2 tractors. It's not a lot of fluid, why not just order it from Amazon or other mail order type company?
Why?? I could see it if you were operating in the Deep South and using it hard, but you're near the Tundra.
whatev
From what I have read, it’s better for the seals in the axle.
I am unable to get SAE 80 gear oil in my location. What is the next best gear oil to use? I would prefer to change it out from hydraulic oil. The tractor is a CK3510. Thanks.
You're saying absolutely NO 80w90 gear oil in your area?
I’m sorry I wrote it wrong. My book says to replace it with SAE 90 gear oil. I can get 75w90 and 80w90 but not SAE 90. Which would be the best? The 75 or the 80 weight. I’m in a colder climate but no extreme cold.
It would take a couple weeks for me to get it from Amazon. I was hoping to get it done this weekend. Living on a island has its drawbacks.
   / Front End Gear Oil #8
I used 80-90w in my RX, that should also be fine for you.
   / Front End Gear Oil #9
A gear oil without a winter rating will be hard to find. 75w90 is a 90 weight gear oil. The 75w "winter" simply means that it will thicken less than say an 80w.
Summary ;
75w90 and 80w90 are both 90 weight gear oils.
75w90 gear oil will thicken less when cold than the 80w90 oil.
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52128)
2019 New Holland...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
