Front Driveshaft Wobble
/ Front Driveshaft Wobble #1
B2400
Platinum Member
Western Illinois
2016 B2650 ROPS, 1998 B2400 (sold!)
Anyone replaced front u-joints on the front driveshaft of their B-Series? I've got the Bi-Speed option on mine and it appears that there is an excessive amount of radial play on the shaft up near the trans. As all this sits up inside the frame tunnel, I can't get a good look at it to see whether it's the joint or the yoke. The WSM is unclear on how to replace this but it appears that they want you to split the tractor to do this /forums/images/graemlins/confused.gif. I plan on using a 2" hole saw and cutting a hole above the yoke to gain access to the roll pins. it doesn't appear that this will weaken the structural integrity at all but if it should I can weld the plug back in place when I'm done. Any tips or suggestions? I'm really scratching my head on this one and plan on attempting it in a couple of weeks when I replace the darn axle pivot o-ring again. Thanks All!!
Update:Winds of fortune have blown my way! The noise I suspected as being a u-joint turned out to be the lower joint cover( at lower u-jont elbow) rubbing on the joint itself!. Slid the cover back about an 1/8 of an inch and no more noise. Radial play in drive shaft is at the spline connecting the driveshaft to the upper,inner yoke. I'd had a similiar problem with a jeep and chevy 4wd and though it's annoying from a mechanical standpoint, it never failed. Sooo.... I live with the wobble until it fails or I hit the lottery to buy a new tractor!
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
2017 Hyundai Elantra Sedan (A61574)
2017 Hyundai...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2018 Trail King Lowboy (A63118)
2018 Trail King...
MacDon 963 Draper Header (A63118)
MacDon 963 Draper...
