sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 5,803
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
My 1100 is 10 speed transmission, 5 gears in low range and then the same 5 gears in high range .
It will seem like you are creeping in low range gears, but when you are working the tractor, it will decide what gear you need to be in, by how the work is loading the engine. If for instance you are mowing, and the engine is having a hard time keeping the rpm's at a constant level, you may need to stop and try a lower gear. If mower is cutting fine and it seems like you are crawling, maybe a gear up would work.
David from jax
David from jax
