foton 404 3pt wont lift
   / foton 404 3pt wont lift #1
dongross
tyner ky
foton 404
after replacing a seal in the hydraulic pump of my 06 foton 404 loader works fine but the 3pt lift wont work it was up when I replaced the pump and worked fine after I replaced the pump I lowered it now it wont raise anyone have that problem be4
   / foton 404 3pt wont lift #2
Yep. I had a line hooked up wrong so it was by-passing in to tank.
only lines I took loose were on the pump and they will only bolt up one way thanks
I took the high pressure line that hooked to the remote hydraulics hooked it straight to the inlet line of the 3ph still wont work sure it the correct line on the 3ph seting in the seat line on the right of the tank that bolts up with 2 bolts ?
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
1955 FORD COBRA REPLICA RACING CAR (A51222)
1955 FORD COBRA...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
