Forum for air cooled diesel engines and clones
   / Forum for air cooled diesel engines and clones #51
Great thread on the Chinese clones of the Yanmar L100 guys. Thought that I would chime in with my experiences with the 186F(SE) as I am now looking down the barrel of a complete rebuild (looks like compression is shot). The generator this thing runs died after 2 years (only about 150hrs) and the engine has just packed it in after a couple of issues.
1. First issue was that the rocker shaft, which was mounted with 2x m8 bolts on the early versions of these engines, was re-designed by its Chinese manufacturers who reasoned that one M10 bolt could do anything that 2 x m8's could do - wrong! replacing 2 symmetrically loaded bolts with a single bolt which is subjected to a large cycling load, encourages the bolt to work loose, then fatigue and break (conveniently right at the interface line with the cylinder head.) This was initially repaired after some judicious drilling and removal of the broken bolt stem with a torx adaptor (don't get me started on EZYOUTs - they are the bane of mankind). Bolt was replaced with a grade 8.8 (high strength) bolt, loctited in position, resulting in a repeat of the original performance about 30hours later. Second attempt, the original bolt and head were drilled and tapped to suit a stainless steel helicoil which now secures a 12mm grade 8.8 bolt (this does do what the 2 m8 bolts from the former design did).
2. Issue 2 - engine just petered out and stopped whilst running under light load about 75 hours later. Checked fuel supply, cleaned and checked fuel injection nozzle and tried a squirt of diesel starter (ether) - nothing. Suspected blown head gasket, so removed cylinder head to reveal heavy carbonisation on the crown of the piston and throughout the combustion chamber. Decided to pull the valves and check the stems, seats and guides for wear or carbon deposits that may have contributed to the valves not seating. Ever pulled valves out of a head that was not fitted with valve stem seals? I have - this one. I guess this is where the Chinese shave another couple of bucks off the cost of building these things. Priced a couple of Yanmar stem seals ($15 each), so did a bit of research for 3 weeks and eventually located some Viton seals - perfect fit and about half the price of the Yanmar rubber seals. Head gasket is solid copper, so I miked it, checked for flatness and consistency, reinstalled the reconditioned head and torqued the head bolts as per the Yanmar manual. Meticulously recreated some sundry gaskets for the bonnet, intake and exhaust, changed the oil and still no start.
Current options are to just bench the engine and use it for spares, purchasing a replacement for around $600 or spend about $200 on parts and refurbish the thing myself - properly. Even though the second option involves more work, I am leaning towards it as I don't want a repeat of the cylinder head issues I experienced with the current engine. What is the consensus amongst everyone? :confused:
   / Forum for air cooled diesel engines and clones #52
David,
A helpful post, and thank you! This will motivate me to do a compare: (Lisa Jackson Approved) VS the early version which does not meet this week's EPA standards.
The first thought that comes to mind is the Chinese made the effort to meet our EPA's new emission standard. What all did the Chinese do to the original CF186 in their effort, and what 'innovative ideas' were incorporated along with those efforts? Perhaps the compliant 186 has the single bolt, and the non compliant effort has two bolts? Could the line be so clear?
I just took a picture of the head with two bolts on the rocker shaft, does anyone have a picture of the single bolt setup? Might make an interesting addition, like to see exactly how they did it.
   / Forum for air cooled diesel engines and clones #53
   / Forum for air cooled diesel engines and clones #54
I ran across a website that has a number of factory parts manuals w/ diagrams including one for the Yanmar TF90 single cyl. diesel. Huge number of manuals for a number of various makes and models, including gas single cylinder and twins too. Too good not to share. リコメント パーツ メイン メニュー:株式会社筑水キャニコム
Thanks for finding that!
I dug around in their site and found their US distributor in Belleview Wa. Apparently Canycom is a Japanese manufacturer of small walk-behind tracked loaders - for pouring concrete etc. (This US site lists the same anti-gray-market policies as Yanmar-USA's site.) They might be a convenient source for engine parts on any of the engines they use in their loaders.
CANYCOM USA, Inc. Home Page
   / Forum for air cooled diesel engines and clones #55
There are quite a few manuals for the 186F diesel from various manufacturers, including a full Yanmar Service Manual and parts list on this site 186F Diesels. They also sell Viton replacement valve stem seals to suit for $15 a pair.
   / Forum for air cooled diesel engines and clones #56
That looks like some interesting equipment.
   / Forum for air cooled diesel engines and clones #57
Lucky that we managed to kick-start this thread again. There has been a lot of very useful information for me and hopefully for all of you.:thumbsup:
Hope that there will be a steady flow of more information :)
   / Forum for air cooled diesel engines and clones #58
A moderator to reply on the status of an air cooled engine would be great.
Where are they?
   / Forum for air cooled diesel engines and clones #59
A moderator to reply on the status of an air cooled engine would be great. Where are they?
This forum is pretty mannerly so maybe nobody official keeps up with every post.
It seems to me the question of an air cooled forum has been kicked around a little here, and there weren't enough separate owners of the things to go split off into a separate forum. (And keep in mind this is an advertising supported site so attractiveness to advertisers is probably considered too). Hopefully the input from Yanmar tractor and implement owners has some relevance to air-cooled owners, for example my last post. I wouldn't have seen mention of Canycom if Kernopelli hadn't posted here. There is some value in having a larger number of people discuss an issue even when they aren't specialists.
Finally - I personally am curious about Yanmar clones (and Lister-type diesels, and biodiesel) so I enjoy reading about this stuff here.
Hey where's Bird? Back when moderators were listed, he was one. I haven't seen a Bird post in a while.
   / Forum for air cooled diesel engines and clones #60
SKLP Massage Chair (A57149)
SKLP Massage Chair...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2012 Ford Fusion Sedan (A56859)
2012 Ford Fusion...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
