Ford 8N...Should I?
   / Ford 8N...Should I? #21
If you want one of the older Ford tractors, I suggest looking at something like an 860 series or above. They have a live pto and a 5 speed tranny. If you can find one with power steering will be even better. My :2cents:
Also, if you plan to use a tiller with this tractor then I would suggest finding something else. Even with the 5 speed tranny, the ground speed is too fast to use a tiller.
   / Ford 8N...Should I? #22
After reading all the replies, many make sense in that it 1) gas doesn't keep long, 2) I'd have to keep two separate fuel cans and 3) no live PTO. Thinking this through, I've decided to look at a Massey Ferguson 135 as another option.
Either of those will make a nice second tractor. Although the nearest fuel station is 20 miles away I never really consider the part about storing fuel; there isn't a tractor made which will run without it, after all. I keep on hand 10 gallons of diesel and 5 gallons of ethanol free gas which I treat when I buy it... when a can gets empty I refill it on the next trip through town.
   / Ford 8N...Should I? #23
My only tractor is a 1957 ford 851. It leaks oil like it free and needs to be held in reverse. But it has a front bucket and starts in -10*F. It sits outside un covered with un stabilized fuel all year long. I prob use it 3hrs a month now.
Its got its quarks and problems but it works and i dont even change the oil in it any more...just add. Around here they can be had for about $2500 in decent condition so its not worth putting a set of rear tires on it, fixinging the rear main seal or any of the other quarks when i could just buy a different one
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A57880)
2018 VOLVO VNL...
INGERSOLL RAND SD-100D SMOOTH DRUM ROLLER (A52707)
INGERSOLL RAND...
2012 Jeep Grand Cherokee (A56859)
2012 Jeep Grand...
2022 John Deere 1025R (A53317)
2022 John Deere...
1993 CATERPILLAR 416B BACKHOE (A52707)
1993 CATERPILLAR...
