ford 6000 troubles
   / ford 6000 troubles #1
jgrieve
Bronze Member
my dad has a 6000 uses it for blowing snow and mowing grass. it has a bad leaking front trans seal it still works ok would it be worthwile to replace the seal? im sure some damage has been done to the selct o speed. the brakes and 3 point arent working, the power steering is. I think they all run off the hyd pump on front? is there a place online where I can see a hyd schematic? any advice would be appreciated. how hard is it to fix a select o speed?
   / ford 6000 troubles #2
I guess this is the 6000 Commander? You might get more responses if you repost here in the vintage section. Another site is ytmag.com. If the select-o-speed is damaged it could be expensive to repair and hard to find parts for. Good luck.
   / ford 6000 troubles #3
Hit the new holland web site.. you can then search for parts and get exploded diagrams.
a MANUAL would be a big help
So far sounds like you go a good engine.. and everything from there back is iffy... gotta love the SOS.. and unfortunately.. for that tractor.. sos was the only trans option... not like you can swap an 8spd into it like you could do with a 5000.. etc.
soundguy
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
Headache Rack (A50860)
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
1.5 Ton Car Jack (A50860)
1.5 Ton Car Jack...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
