Backhoe Ford 555b backhoe shifter
   / Ford 555b backhoe shifter #1
paulownia
Greetings all,
I am looking at a ford 555b to purchase. Probably a late 80's model.
Cranks and runs good. However the forward lever does not go into forward easily. It goes but the transmission does not engage. Ya can go from reverse to forward and it goes every time. Just from neutral to forward it does not want to engage.
Is this simply a linkage problem or a transmission problem.
If so how to tell??
David d.
   / Ford 555b backhoe shifter #2
Greetings all,
If so how to tell??
David d.
There are a half dozen roll pins and several joints in the valve linkage. Some or all are probably loose enough to cause those symptoms.
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
1-Pallet Misc. Items (A50860)
1-Pallet Misc...
2-Row Hiller (A50860)
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
