Ford 4630 steering problems
   / Ford 4630 steering problems #1
MGriff
Or
blue ones
Hello. We have a non turbo 4630 w/FWA and hydrostatic steering. When tractor is cold the steering wheel will not stop rotating at the 'stops' will just keep turning. After it is at operating temp it will rotate properly. But on a flat smooth surface, holding the steering wheel straight, the front wheels will drift off into a turn, it will not run straight for even a short distance. Anybody have any experence with these? Any guesses if it is steering cylinder or valve? Thanks in advance
   / Ford 4630 steering problems #2
Use OEM parts, I would first change fluid & filter, check for leaks, inspect all steering components visually & hands on making sure components are tight & secure.
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
2020 KUBOTA RTV...
UNUSED U Bolt Wire Rope Clamp Set (A50860)
UNUSED U Bolt Wire...
Deere 9965 Cotton Picker (A51039)
Deere 9965 Cotton...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2017 Mahindra 85P 4WD Tractor (A50860)
2017 Mahindra 85P...
