Ford 4000 With Sherman Combo Transmission
   / Ford 4000 With Sherman Combo Transmission #1
GWheat
So I got some new parts for the tractor today so I decided to pull the tarp and install a few of them. I was playing with the steering wheel when I saw the Sherman plate on it. Was wondering if this is the shifter for the step up or step down. Or maybe it’s a steering wheel off a 8N or 9N? Thanks
   / Ford 4000 With Sherman Combo Transmission #3
Not sure what you mean. Sure looks like the handle for the Sherman combo to me.
Basically what I was asking if it was the shifter. Although I can’t seem to get it to pop out to go into standard gears. Only the high and low gears.
   / Ford 4000 With Sherman Combo Transmission #5
You need to hear from "Soundguy".
He will likely be able to explain it best.
   / Ford 4000 With Sherman Combo Transmission #6
I have seen this before when a previous owner never used the middle range and the tractor spent time sitting outside.
Since you have it moving forward / backward, move the shifter to the half way position. Now pull outward while rocking it slightly back and forth. Try spraying some penetrating oil around where the shifter goes through the casting before you start. It should move out and to the rear for the middle or straight range.
   / Ford 4000 With Sherman Combo Transmission #7
You have to pull out on the handle to get it to standard gears
   / Ford 4000 With Sherman Combo Transmission #8
Here's a nice video that explains it. Advance to :53.
2013 MACK GU713 (A50854)
2013 MACK GU713...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
