Ford 4000 3 point hitch either up or down
   / Ford 4000 3 point hitch either up or down #1
get stuck
Seattle, Washington
Ford 3000
Hi all!
I have a 1967 Ford 4000 with a bucket. The problem is that the 3 point hitch is either in the up position or the down position, it will not adjust and stay anywhere in between. The bucket works just fine which leads me to think the hydraulic pump is working.
New fluid, new external filter.
Would like to get this fixed cause it make brush hogging difficult.
   / Ford 4000 3 point hitch either up or down #2
Find the draft/position selector lever and put it in the position setting. Short lever protruding from the Rh side of the 3PT hitch cover.
Another piece of useful information that one would find in an operator's manual.
   / Ford 4000 3 point hitch either up or down #3
I would have to go out and look, but I think the position/draft lever on our 4000 is under the seat on the right side. Occasionally the lever gets moved on our tractor and it takes me a few minutes each time to figure out what is wrong. When in the draft position you have up or down.
   / Ford 4000 3 point hitch either up or down #4
Same location, different description.
2018 PETERBILT 567 (A50854)
2018 PETERBILT 567...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2012 John Deere 7230R (A51039)
2012 John Deere...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
