3-Point Hitch Ford 3400 3 point problem
   / Ford 3400 3 point problem #1
snorulz
Hello,
I have a Ford 3400 and the 3 point hitch is acting up. The hitch will only go all the way up or all the way down, you can't get it to do anything in between even if you only move the lever just a little bit. What would cause this problem?
   / Ford 3400 3 point problem #2
Does the tractor have a selector for either Position Control or Draft Control? It sounds like you may have inadvertently selected Draft Control. In draft control, the implement only raises slightly as the tractor senses a change in plowing depth. This is normally sensed by toplink compression. The hydraulic lift either raises the implement or drops it all the way as you indicated in your post.
If you have position control selected, you could have something broken or out of adjustment causing the 3PH to only respond as it would in draft control. I don't have specific knowledge of your tractor to give you any more advice than that.
It does have the option for draft control but i tried the lever in both spots and it seems to act the same.
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
91013 (A48082)
91013 (A48082)
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
