ford 3000 generator
   / ford 3000 generator #1
jgrieve
Bronze Member
my dad has a ford 3000 with a lucas generator which is not charging. The plate on the back end of the gen is broken. This is the back cover and the rear mounting bracket. Where can I get a replacement bracket? I would like to replace with a alternator but the tack drives from the generator. Is there any other way to drive the tack?
   / ford 3000 generator #2
yep.. you can grab a suitcase of cash and get a delco 10DN with a tach drive and external regulator.. OR.. you can just have your gen rebuilt at a rebuilder. OR you can buy a new replacement model.. I see alot of indian models... I got a spare one on the shelf from india.. I'd normally guess that it wasn't as good as oem.. but then oem was lucase.. so.. :) the indian one might be better.
seriously though... new gens for the 65+ models are easy to find and affordable.
Discount Tractor Parts and Manuals for Older and Antique Tractors System&r=mcats
a whopping 89$
Generator, 12 Volt - For models (2000, 3000, 4000, all after 1965 gas or DSL engines), (620, 8000 both 1968-75 with DSL engines), 9000 1968-1975 with DSL engine. (Part No: C9NN10000A)
or. swap your old pulley over and tach drive and pay 79$
Generator, Less Pulley & Tach Drive - New Generator 12V, 22 amp - 1965-75 2000, 3000, 4000, 5000, Gas and Diesel, (620, 622 1967-74), (7000 1971-75 w\ 4-256), 1968 All 8000, 9000 series (up to Dec\1969). INDUSTRIALS: 2110LCG, 3400, 3500, 3550, 4110LCG, 4400, 4500. LESS pulley & tach drive. Pulley is available (see p\n C5NF10196B). Tach Drive available (see part #C5NF17B282B). Replaces Lucas 22756. (Part No: C7NN10000C)
http://www.ytmag.com/store/parts/pics/wm_C7NN10000C.jpg
soundguy
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2006 International 9400i (A51039)
2006 International...
2009 International Ambulance (A49461)
2009 International...
