FordnMassey
- Joined
- Jan 22, 2022
- Messages
- 171
- Tractor
- ford 3000 and MF35
Hi,
I have a Ford 3000 3cyl diesel from 1967, UK build, with a Simms fuel pump priming problem. I've owned it around 2 years, and throughout that time found the fuel system will lose prime if it's not started for some time. Started once a week there's no problem, but at around 2-3 weeks between starts the cranking time becomes noticeable and it starts on 1 or 2 cylinders before building to all 3 over 1-2 minutes. If it is left 3-6 weeks, it simply won't start and needs priming. Once started it runs and works beautifully with smooth powerful, clean running under light and heavy load and at idle. No visible leaks except thru the fuel tap handle shaft, which is slow and improved with a new O-ring.
Anyone got ideas on why it loses it's prime?
Thanks in advance for ideas.
FordnMassey
FordnMassey
